Can the New Camry Hybrids Headlight be Raised?
Discussion in 'Toyota Hybrids and EVs' started by Philip_pc, Oct 29, 2016.
  1. Philip_pc
    Philip_pc Junior Member
    Australia
    The headlight seems to be pointing a bit down for my liking so I want to raise it up a bit but cannot locate the vertical knob/dial/screw, does this car have one? I found the left and right one though. Anyone know?
    I've attached pictures of the actual car as I know the one in Australia is slightly different to the one in states and Asia.
    Many thanks guys.
    The one I circled is the right left screw I believe.
    SM-G920I ?
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    As always, read your owner's manual. You'd be surprised at how much information you can find in it. ;)
  3. Philip_pc
    Australia
    Nothing in the owners manual mentions aiming headlight. I've checked. It was the first place I went to
    SM-G920I ?
    49,492
    welcome! how new is it? will the dealer do it under warranty? not a lot of hycam owners here, but hopefully someone will know. all the best!(y)
  5. Philip_pc
    Australia
    This is a Aug 2015 one
    SM-G920I ?
  6. Philip_pc
    Australia
    I found it actually, in the photos above. It's that white hex screw right next to the water washer bottle
    SM-G920I ?
  7. bisco
    49,492
    well done! perhaps this will help someone else. ours is july of 2013, older style.
  8. xliderider
    7,869
    3,116
    Honolulu, HI
    Are you sure? That looks like a regular mounting tab.
    There isn't a regular hex bolt, with a serrated ring next to it at the back of the headlight housing, the silver hex head near the center of the picture of my passenger (right) side headlight:
    Took this picture from the front, with my phone pointing downward, back to front.
    The bolt is between the lowbeam and the highbeam connectors at the bottom of the housing. Turn clockwise to lower beam, counterclockwise to raise the beam.
  9. Philip_pc
    Australia
    It definitely is. I gave it a go and the lights definitely moved up n down
    SM-G920I ?
