Can the Prius run on ethanol?
Discussion in 'Gen 2 Prius Main Forum' started by ctomberg, Nov 19, 2006.
  1. ctomberg
    ctomberg New Member
    I was told today at a green conference today by a man who wrote a book on using ethanol as a fuel that the Prius can run on pure ethanol without modification. This was news to me. Has anyone tried this? Does it work? What about E85?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    No. The Prius is not a flex fuel vehicle. Don't run it on 100% ethanol or E85 unless you want possible corrosion to the fuel system and lines along w/other possible damage + a check engine light.
    Someone on here already has tried it.
  3. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Will it run?
    Yes, but not for long.
  4. narf
    narf Active Member
    611
    44
    Colorado
    Four Touring
    For a more complete answer, read :MSU Study on running a 2003 Prius on E85
    They conclude that you can run the car on E85 without modifications, but it will eventually trigger a check engine light because the computer has to run the engine way outside the base fuel mixture programming when E85 is used.
    They also warn that the effects of E85 on rubber and plastic parts of the fuel system is unknown.
  5. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    <div class='quotetop'>QUOTE(narf @ Nov 19 2006, 10:53 AM) [snapback]351703[/snapback]</div> That's where I got my bachelor's degree.
    Small world, eh?
  6. Alnilam
    Alnilam The One in the Middle
    760
    Carlsbad, CA
    <div class='quotetop'>QUOTE(CharlieT @ Nov 18 2006, 11:01 PM) [snapback]351619[/snapback]</div>
    Only if the battery is fully charged. That's why we bought hybrids!
  7. IndyDoug
    IndyDoug New Member
    120
    Indianapolis, IN
    please read the manual in your glovebox.
  8. Leo
    Leo Leo
    81
    Ottawa, Canada
    As John1701 says at http://john1701a.com/prius/prius-advice.htm you can use 10% Ethanol (E10) in the Prius with no problem. In fact, that's what's in my Prius right now. The corner station here in Ottawa sells it at the same price as regular. Octane has been boosted to 89 to compensate for the slightly less energy in Ethanol.
    My Canadian Prius manual says E85 is fine.
  9. Tempus
    1,690
    Washington DC
    <div class='quotetop'>QUOTE(Leo @ Nov 19 2006, 06:28 PM) [snapback]351835[/snapback]</div>
    Could we please get an image of that statement in the manual?
  10. Tideland Prius
    16,127
    <div class='quotetop'>QUOTE(Leo @ Nov 19 2006, 03:28 PM) [snapback]351835[/snapback]</div>
    Are you sure? Mine doesn't
    "CLEANER BURNING GASOLINE
    Cleaner burning gasoline, including reformulated gasoline that contains oxygenates such as ethanol or MTBE is available in many areas. Toyota recommends the use of cleaner burning gasoline and appropriately blended reformulated gasoline. These types of gasoline provide excellent vehicle performance, reduce vehicle emissions, and improve air quality.
    OXYGENATES IN GASOLINE
    Toyota allows the use of oxygenate blended gasoline where the oxygenate content is up to 10% ethanol or 15% MTBE. If you use gasohol in your Toyota, be sure that it has an octane rating no lower than 87. Toyota does not recommend the use of gasoline containing methanol.
    GASOLINE CONTAINING MMT
    Some gasoline contain an octane enhancing additive called MMT (Methylcyclopentadienyl Manganese Tricarbonyl). Toyota does not recommend the use of gasoline that contains MMT. If fuel containing MMT is used, your emission control system may be adversely affected. The Malfunction Indicator Lamp on the instrument cluster may come on. If this happens, contact your Toyota dealer for service."
  11. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(cwerdna @ Nov 19 2006, 04:06 PM) [snapback]351620[/snapback]</div>
    Then, there is a possibility to catch a fire.
    Ken@Japan
  12. pinball
    pinball New Member
    121
    Surrey UK
    <div class='quotetop'>QUOTE(Tideland Prius @ Nov 20 2006, 07:57 AM) [snapback]352003[/snapback]</div>
    Has anyone tried adding a few drops of acetone to the gasoline ? Supposedly it improves combustion so the ICE consumes less and so your FE increases
    http://www.pureenergysystems.com/news/2005...900069_Acetone/
    and
    http://priuschat.com/index.php?showtopic=8573&hl=acetone
  13. tonyt
    tonyt Junior Member
    Southern California
    What about E20? Minnesota is talking about moving all the stations to E20, what would that do to the Prius?
  14. tochatihu
    tochatihu Senior Member
    9,045
    3,528
    Kunming Yunnan China
    2001 Prius
    In the Yahoo toyota-prius-technical group, one person was experimenting with different proportions of ethanol last year or so. They got 'engine lights' above either 25% or 50%, sorry I don't remember which. As noted here, the question of long-term stability of polymers in the fuel system has not been resolved.
    If E20 were my only choice I would not hesitate to buy a tank. For a steady diet I would not be anxious to go above E10. The energy content of these mixed fuels is a little lower than 'puire gasoline' so a small mpg hit could be expected.
    Experimentalists with sources of E85 could try different proportions by filling from two different pumps. But I am not suggesting that you do so.
  15. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    <div class='quotetop'>QUOTE(pinball @ Nov 20 2006, 04:08 AM) [snapback]352015[/snapback]</div>
    I think this has pretty much been beaten to death on here as an urban myth and a bad idea in general. First, Acetone is a paint thinner, so you'd better not drip any, or you'll start loosing your paint down the side of the car. Second, there haven't been any conclusive studies to show that it actually works (at least, none that i could find). Lastly, with the bladder, hoses, and seals, it's not a good idea to be adding chemical mixtures to the gas that could have the potential to corrode these rather expensive parts.
    HeadOfJarg likes this.
  16. john1701a
    12,754
    5,245
    57
    <div class='quotetop'>QUOTE(tonyt @ Nov 20 2006, 08:48 AM) [snapback]352050[/snapback]</div>
    The base studies (which the new mandate came from) of non-hybrids showed that E20 worked just fine. Funding has been provided for extensive research/certification efforts to prove that for all vehicles, including hybrids.
    For the owner point of view, efficiency takes a minor hit but horsepower is actually increased a little.
  17. GeronimoPFudgemuffin
    62
    Well, not exactly. The octane rating of pure ethanol is higher than that of normal gasoline, so any ethanol added would raise the base gasoline's rating. E10 is supposed to be a couple of points higher on the octane index than the base gasoline from which it was made.
    The higher octane rating of E10 is simply a by-product of the process, and not an "added benefit." Some ethanol-centric sites claim the octane "helps improve engine performance." This is a most disingenuous statement as it claims higher octane as a performance benefit while neglecting to report the performance hit one takes with ethanol because, even though it has a higher octane rating, there is less energy content (BTUs) in ethanol as compared to gasoline.
    I'm not anti-ethanol, but calculated obfuscation causes a typing reflex in me.
  18. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    I want to know if the Prius is qualified on Butanol. Butanol could the be the base chemical in Bio-Gasoline.
  19. bongobennie
    bongobennie New Member
    hello hybrid owners, I converted my 2004 Honda Civic to run on strait E85, there are alot of myths about the stuff. I know it can be done, but tuning is mandatory. Im still in research on honda related projects, but would love to hear from anyone interested.
  20. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    <div class='quotetop'>QUOTE(tonyt @ Nov 20 2006, 06:48 AM) [snapback]352050[/snapback]</div>
    The manual says 10%, which is E10.
    If you run any higher percentage of ethanol, then you're on your own. Toyota might not have tested higher percentages. They certainly don't suggest you go beyond E10.
    You may find that doing so constitutes operation beyond the limits of the warranty.
    <div class='quotetop'>QUOTE(donee @ Nov 20 2006, 04:51 PM) [snapback]352340[/snapback]</div>
    The manual doesn't mention Butanol at all.
    <div class='quotetop'>QUOTE(bongobennie @ Jan 27 2007, 12:20 AM) [snapback]381597[/snapback]</div>
    Since you don't have access to the computers and software that control the hybrid system, I doubt that you can tune the engine to work properly within the system. And that still says nothing about the fuel tank bladder, fuel lines, etc.
