Can the smart entry wear out?
Discussion in 'Gen 2 Prius Main Forum' started by qmanqman, Oct 27, 2024.
  1. qmanqman
    qmanqman Active Member
    335
    118
    CO
    Daughter's Prius has 320 kmi on it. She says the smart entry no longer works. Is this a wear item and can it be fixed?
  2. Tombukt2
    Tombukt2 Senior Member
    11,988
    2,116
    Durham NC
    Is the button under steer wheel pushed in by accident?
  3. Brian1954
    Brian1954 Senior Member
    1,698
    663
    South Central PA, USA
    Replace the battery in the FOB.
    97trophy likes this.
  4. fuzzy1
    10,335
    The only wear item should be the fob's battery. But the system can be turned off, or suffer component failure.
  5. goodwin
    goodwin Junior Member
    Toledo, OH
    We've owned 5 prius and when my daughter had me look at hers today (#6 prius in the family) and the smart entry didn't work- your post above fixed it-- I've never known that button existed- right next to a button to reset the Low Tire warning which I never knew existed. thanks!
  6. Tombukt2
    11,988
    2,116
    Durham NC
    Yes the button can get pushed by the person washing and vacuuming your car or it's kind of anything like that Glad that you were able to figure out that nothing's worn out because in our four nothing like that is ever worn out almost everything else has but this is an extreme mileage conditions too we're all above 300 K
  7. fuzzy1
    10,335
    Beware, that TPMS warning button isn't really a reset button, so don't use it to make a low pressure warning go away. It is meant to adjust the threshold pressure that trips the warning. Using it incorrectly may hide slow leaks.
    Brian1954 likes this.
