Can the supplied charging cable be used for 240 volts?
Discussion in 'Prime Plug-in Charging' started by Jim Bossenbroek, Aug 19, 2019.
  1. Jim Bossenbroek
    Jim Bossenbroek New Member
    Columbus, OH
    2020 Prius Prime
    Just took delivery of my 2020 prime limited. Awesome ride. This is a great vehicle. It replaces a 2008 Prius. Can the supplied charging cable be used for 240 volts? the YouTube video from joetechtipsoetechtips says it can. (Sorry about Having to disguise the URL). Does anyone have any official information from Toyota that says it can or can’t? I’m not looking for personal opinions. Can anyone quote the official word from Toyota?
    Also anther issue... I can’t seem to get the HUD to activate. It worked one of the short trips I took but it is no longer working. I’ve combed the manual to no avail. There must be some setting I’m missing. Any help is greatly appreciated.
    Thanks, Jim
  2. Tideland Prius
    16,677
    Arctic_White and Rob43 like this.
  3. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Welcome to PriusChat !
    Hi Jim,
    I'm Rob43 and I am the source of Joe's helpful video. So yes, your 120v OE Toyota EVSE works flawlessly at 240 volts all day long. I build perfect working high quality Pigtails using all copper & 10 AWG wire, let me know if you want one.
    Rob43
    #3 Rob43, Aug 20, 2019
    Arctic_White and jb in NE like this.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    [Note: I bought a 6-20p to 5-20r pigtail myself]
    Since the wisest way to implement a 240 volt adapter for the EVSE cable uses a 120 volt receptacle mis-wired to provide 240 volts.* No company in the world would have an official position that this was a good idea. Individuals have confirmed that the electronics are identical between European (240) and North American (120) delivered cables.
    If you go this way, it is your responsibility to prevent random people from plugging 120 volt only devices into a receptacle that looks like 120 volts but supplies 240 volts.
    *The Prime cable contains needed thermal circuitry in the 120 volt plug, so just cutting it off and replacing it with a 240 volt plug is not wise.
    #4 JimboPalmer, Aug 20, 2019
    Raytheeagle and jb in NE like this.
  5. Jim Bossenbroek
    Columbus, OH
    2020 Prius Prime
    Yes, I do that, and except for the one brief trip, it just doesn’t work. Here’s another odd tidbit. When I turn on HUD the screen to modify the HUD settings appears. The left and right buttons control the brightness fine, but the up and down arrows do not change the elevation. As a matter of fact, there is a very faint hum when the up and down arrows are pressed.
  6. Jim Bossenbroek
    Columbus, OH
    2020 Prius Prime
    Yes, good cautionary advice. I will install a 240 volt outlet and use an adapter for the charging cable.
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    In my case I have a 20 Amp breaker and line running to the outside of the house, so I used that with a 6-20r. If it is a clean sheet design, I would have my electrician use a 50 Amp breaker and a 14-50r receptacle for the 240.
    Here is a custom cord adapter designer
    NEMA adapters
  8. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    Wow...
    The Adapter Link you posted is the BIGGEST RIPOFF I've ever seen !
    With shipping prices are over $100 dollars.
    Rob43
    mveras1972 likes this.
  9. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    If you can post a website with custom adapters, I would use that.
  10. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    Great !
    But why do I need a "Website" to build a great custom adapter ?
    As you can see from all the different posted pictures and testimonials, my $49 adapters work Perfectly.
    Rob43
    Arctic_White likes this.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    If you have no link, i can't post a link.
  12. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Here's one. @Rob43
  13. ctscoob
    ctscoob Junior Member
    56
    36
    CT
    2020 Prius Prime
    There are some videos on YouTube with guidance on the HUD. Just search “how to use HUD prius prime.”
