Can this be?
Discussion in 'Environmental Discussion' started by Montgomery, Oct 25, 2019.
  1. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
  2. fuzzy1
    10,166
    "Technically, it should be described as a fuel cell, not a battery."
    This sounds like a primary (i.e. non-rechargeable) metal-air cell, so it cannot be directly compared to a rechargeable-in-place battery. The metal "fuel" is oxidized during use, then must be swapped out and replaced with fresh material. The old stuff, in this case the entire unit, is sent back for recycling / "recharging" / chemical reduction. The refining process consumes a lot of electric energy, enough so that some folks have described aluminum as 'electricity in its solid form'.
    I'm also guessing that the range estimate is for an optimistic hypermiler, not conforming to EPA or possibly even Euro mileage rating rules.
  3. Trollbait
    11,517
    Phinergy has been working on Al-air batteries for EV, but they use it as a range extender to a rechargable battery. IIRC, their test BEV had about 80 miles of grid range and a thousand from the Al-air.
    Phinergy - Wikipedia
  4. kenmce
    kenmce High Voltage Member
    1,528
    504
    NY
    Surely the Metro would never fail to fact check any difficult technological questions..
  5. bisco
    49,401
    everything about this article and the inventor smells of hype
