Can we make our Prius 5 try to use recycled air to defrost the windshield?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bellingham PRIUS 1811, Dec 23, 2013.
  1. Bellingham PRIUS 1811
    Stupid question, I know, since you are supposed to always use outside air for defrosting. Knowing this, the Prius deals with our foolish actions by helping us, switching to outside air whenever we turn to defrost to make the defrost work faster and better.
    BUT . . . I have a very allergic wife who hates to breathe the exhaust air when we drive. So she refuses to use outside air at any time. The PRIUS is thus in mothballs until spring. Can anyone suggest a way to override this? Kind of a shame not to use our new car instead of our 14 year old Subaru Forster all winter long.
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    As long as it is already defrosted, just turning the cabin to AC (dehumidify) and recirc should work. If it is foggy, then you will need to tough it out for the 2 or 3 seconds it takes to defrost. The Prius defrosts faster than any other car I have ever had. My GenII literally takes 2-3 seconds to clear a 100% fogged up windshield to crystal clear. I drive with the HVAC off all the time so when I need defrost, I turn it on for a couple seconds then turn it off again for the 10-20 minutes before it starts getting foggy.
    hybridbear likes this.
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    wrong answer lmao
  4. Bellingham PRIUS 1811
    That was our work-around, but there must be a more elegant solution.
  5. bisco
    49,437
    if you put it on recirc, it stays for awhile and switches to outside. i think you just have to keep switching it back? maybe the dealer can reprogram it, but i don't think it will defrost/defog with inside air.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I would expect that someone will have to defeat the mechanics to change the ducting, I do not think even the dealer can change the software.
  7. fuzzy1
    10,167
    I keep wondering how people think they can keep the inside air as clean or cleaner than the average outside air, without installing reliable air seals and bringing along an auxiliary source of air to continuously flush out the human respiratory exhalations and the out-gassing the inside materials.
  8. lizardskin
    lizardskin Junior Member
    26
    Northeast USA
    I have a 2010 Prius.
    Basically, you turn on the system (sorry it's so automatic that I don't remember the exact buttons, so I think I press the AUTO button), then press the the MODE button until you get both the defrost and foot warmer icon. Then you can press the RECIRC button (fresh air in to the other one, which should be RECIRC) so you are using indoor air = defrost + indoor air.
    This should allow you to defrost, albeit at a lower level/flow since some of the air is directed towards warming the feet, which I need if I was only using outdoor air to defrost. So this is usually run at a higher fan speed than if I were to use Defrost alone.
    And I don't think you have to defrost with outside air (which should be cold) necessarily. I think defrosting with warmer air will remove the condensation (humidity) the same rate if not faster.
    Regarding k21Toasters comment, I think the prius has the WORST defrost due to the slope of the front windshield and the location of the blowers - only the lower half of the windshield is clear and the top half of the windshield will fog up immediately if I turn off the defrost in the winter or on a rainy day. I can live with is as this is one of the design features that improves the gas mileage.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    We get really cold down here, but less humid. In these scenarios, it works the best of any car I have been in. Almost instant relief.
  10. bisco
    49,437
    yes, our humidity can be 'wicked'.:cool:
  11. mrbigh
    3,686
    699
    Long Island, NY
    We at the coastal N East of the country, are suffering from humidity stress almost at all times :censored:
  12. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Just got back from a ski trip, driving back in a snow storm. Turned the car on as I took my boots off and loaded my skis and by the time I drove off, the cabin was warming, the windshield was defrosted and melting, and the rear hatch had melted the ice off so I could wiper it away. :)
  13. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    The only time the Prius draws no outside air is when it is in the 3 minute filter mode.
  14. lizardskin
    26
    Northeast USA
    yeah, I won't doubt that ^. My feet are cold all the time, even on recirc!
