can you add rs 3200 security system
Discussion in 'Gen 2 Prius Main Forum' started by setheriah, Feb 28, 2007.
  1. setheriah
    setheriah New Member
    40
    Can you add an RS 3200 security system to a prius non touring package 5 after the purchase of the car as well as the glass breakage sensor or is the rs3200 a factory installed item only.. I went to four dealerships and got a split down the middle on whether I can add the security system or not.. 30 miles driven so far.. great car so far
  2. Tideland Prius
    16,445
    Engine immobiliser is standard, alarm is opt. You can technically get your technician to activate the alarm without purchasing it. Dan over at PriusOnline can help you (unless someone else here remembers the steps).
    The GBS is an accessory.
