Can you assume a 2.5 hour L1 charging time?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by iRun26.2, Mar 25, 2012.
  1. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    The user's manual says the L1 charging time may require up to 3 hours for a full charge. It ALWAYS is about 2.5 hours for me (and that's what I've heard from other people, too).
    Does anyone, as a standard practice, just assume that 2.5 hours is enough?
    (I'm thinking about planning for this 0.5 hour offset so my car 'really' is just charged before I leave for work in the morning, rather than being fully charged 1/2 hour before I told it to be).
    51,711
    are you starting from empty?
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    When my dads is completely dead with no EV left it takes 3 hours at 110. I don't often charge from dead since I charge more often than he does. Well, he also is forced more often to do more than 13 miles in EV throughout the day with no access to plugging in.
    What does it matter though if it finishes charging 1, 2 or even 3 hours before you leave for work?
  4. mikenewmediary
    100
    24
    Bridgewater, Ma.
    Sorry for asking, but does it matter when the charge is completed?
  5. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    The Toyota manual says to charge it just before you use it. It's not good to let a Li-Ion battery stay fully charged for long periods of time (several days or weeks). A few hours won't make any difference.
  6. iRun26.2
    824
    169
    United States
    I guess I am too much of a perfectionist. I'll still allow 3 hours when using the 'Start' timer function.
    Also, I just read at page 90 of the user's manual that the charge time will take approximately 2.5 hours. I guess the 3 hour figure is just to be certain.
  7. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    Mine takes about 2 hours and 40 minutes over a 110 line. It is not a dedicated circuit, but I don't think there is much else on it.
  8. iRun26.2
    824
    169
    United States
    The manuel also says that the charging time with vary with the temperature. I wonder how that will work (longer or shorter charge times in winter or summer)?
  9. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Perfectionist aside, is there a concern of having it start at say midnight and end at 3am and sit charged at full until you leave whenever that is, say 6am, 7am etc? Having it charge and sit (we're talking hours not days) is not going to affect your battery if that's the concern.
  10. CharlesH
    2,796
    1,163
    Roseville, CA
    Say your car won't be driven for a week. So one would not want to leave it fully charged, but is it better to have it "discharged" (i.e., at HV level), or partially charged?
  11. drash
    drash Senior Member
    2,573
    1,311
    Upstate NY
    Anything less than half charged is fine especially for only a week.
  12. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    partially charged is fine.
  13. bisco
    51,711
    are you guys making this up as we go along or is the manual clear on all these different concerns?
  14. drash
    drash Senior Member
    2,573
    1,311
    Upstate NY
    The manual says don't leave it fully charged and parked for long period unused.
    Physics of both Lithium and Nickel-based batteries are if you are going somewhere for a long time it is best to leave the battery in a lower charged state. Lead acids of course should be stored fully charged. They have somewhat reversed types of problems.
    2 people like this.
  15. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Here's exactly what the Owner's Manual states on pg. 93:
    2 people like this.
  16. RiverRat
    RiverRat Junior Member
    24
    Huntington Beach CA
    Doesn't heat also shorten battery life? I would think a short cooling period for the batteries, before heat generating discharge would also extended life.
  17. jbrad4
    474
    148
    Rowlett, TX
    Yes. All true. That's why I plan on charging early in the morning on the days that I will be driving my Plug-In.
  18. iRun26.2
    824
    169
    United States
    What I fond interesting is that they didn't mention anything in this section about not charging immediately after driving. I thought I remember reading that you should try to let the car sit a while before recharging but I don't remember where I saw that.
    (I am guilty of that couple times per week)
  19. ryogajyc
    985
    165
    Reseda, CA
    The L1 and L2 charging power is ~1kW and ~2kW to the battery, which is very low compared to the charging/discharging power during driving. For example, maintaining 35mph discharges the battery at ~9kW, so charging is not really stressing the batteries.
    I recall a forum member posting that as well, but that was his explanation for "Use the charging timer function as much as possible in order to fully charge the hybrid battery (traction battery) immediately before starting off." However, considering the charging/discharging rates during driving makes it an unlikely explanation, IMO.
  20. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    fwiw, recharge times have usually been about 2:20 when just the EV battery is depleted to 0.
    doing errands this morning, i arrived back in garage down 3 bars on the HV portion of the battery, and recharge time indicated 2:45
    Maybe the full 3 hours is when the HV portion of the batt is fully depleted?
