Can you force the engine to turn on?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Edmund, Sep 7, 2014.
  1. Edmund
    Edmund Junior Member
    Los Angeles
    2014 Prius c
    Hi guys! Long time reader, first time poster.
    I was wondering if I could force my engine to start while in ev mode. Reason being is that while accelerating from a stop on a hill, the delay for the engine to start is a little annoying. Any comments or opinions will greatly appreciated!
    Cheers,
  2. Stevie
    Stevie Junior Member
    95
    22
    Melbourne,Victoria,Australia
    Interesting question, I find I need to do this when trying to use an oil flush additive before an oil change, I have found by pressing both the accelerator pedal and the brake pedal the engine starts, (sorry I cannot remember what position the gear selection is in) - I must admit however I did decide this may not be the best option and should just drive the car to let the additive do it's work
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    With the car in park, foot on the brake, you can press the accelerator and run the ICE at about 2000 RPM. There is no problem doing this. Some people do this to "force charge" the HV Battery.
    For hills, if you press the brake a little harder than normal an indicator will show on the MID indicating Hill Assist. This will keep the brake engaged for a couple of seconds until MG2 can develop torque and prevent rollback. The ICE may start depending on accelerator position.
    minkus and telmo744 like this.
  4. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    On my UK PiP turning on the windscreen de-mist forces the engine on.
    Does that work for you?
  5. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Judt push down on the gas pedal. The engine will start.
  6. fuzzy1
    10,165
    Always? Or just during certain warmup stages or conditions?
  7. IanIanIanIan
    IanIanIanIan Member
    152
    56
    2013 Prius Plug-in
    Always, unfortunately.
  8. jdcollins5
    5,131
    1,338
    Wilmington, NC
    I tried mine this morning sitting in the dentist's parking lot. The ICE was warm and off. I tried the Front Windshield Defrost and the ICE did not come on.
    minkus likes this.
  9. usnavystgc
    3,159
    989
    Tucson, AZ
    My question for the OP is, why are you in EV mode when approaching a hill? But, if you want the engine to start, simply press hard on the gas when you take off or, put your foot on the brake and press the gas as others have said. I don't know what you mean about a delay all my hybrids start the ICE without delay.
    minkus likes this.
