Can you have 2 active FOB keys?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by drewker, Dec 25, 2019.
Tags:
  1. drewker
    drewker New Member
    23
    Phoenix, AZ
    Hello. I have 2 FOBs for my 2005 Prius, but only one works. I would like to activate both however because the original one is weathered and acts weird at times. Before performing the 'chicken dance' procedure as outlined on this site I wanted to know if this is even possible. Thanks
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Both fobs should work. Are you sure both batteries are OK? On the other hand, my wife's '7 came with one that works the SKS and the other one doesn't work the SKS, but will start the car if I plug it into the slot in the dash for the non-SKS (or dead battery) fobs.
    BTW, you may want to edit your vehicle model information. If it's a 2005, it's not a Plug-in unless it's been SERIOUSLY modified. ;)
    drewker likes this.
  3. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Yes, AIRC you can have up to 5 active FOBs.
    drewker likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    The SKS version Gen 2 can have up to 5 FOBs active.
    The non-SKS version can have up to 4.
    And that only jumps out at me because I was reading through an owners manual over the holiday and thought it was a bit odd....
    drewker likes this.
  5. drewker
    drewker New Member
    23
    Phoenix, AZ
    Ok thanks much for the replies. So I guess the 'chicken dance' procedure is how to do it? I did not want to deactivate the key that works in this process in the event I mess up the procedure.
  6. drewker
    drewker New Member
    23
    Phoenix, AZ
    I will change the battery on the other one today, but I thought it had to be programmed or whatever. It might just be a dead battery
  7. RobH
    RobH Senior Member
    2,374
    987
    70
    Sunnyvale, California
    The worn fob may have degraded rubber buttons that jam at least one button ON. Replacement cases are available for around $10 or so. Be sure to move the transponder chip as well as the circuit board to the new case. Original cases are glued together, so spread some needle nose pliers in the mechanical key slot to open the old one. New cases are just snap together.
    jerrymildred likes this.
  8. drewker
    drewker New Member
    23
    Phoenix, AZ
    it was the battery on the fob. now have 2 active fobs. thanks for the assistance.
