Can you increase mileage with wheels?
Discussion in 'Gen 3 Prius Main Forum' started by lizardacres, Mar 19, 2013.
  1. lizardacres
    lizardacres Junior Member
    43
    Portland, Oregon
    2024 Prius Prime
    XSE
    In the history of this board, has anybody ever increased their mileage by changing their wheels? It seems like it could be possible if you used a small rim lighter than the OEM, but are there any specific examples? I really want to change the wheels on my new Prius but don't want to sacrifice mileage; well, not more than 1-2 mpg. Just hate to make an expensive mistake.
  2. matt b.
    matt b. Member
    251
    60
    L.A.
    You already know the answer. Leave well enough alone or , could be a costly mistake
  3. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Making safe wheels light weight is not a cheap business. For $400 a wheel I can find 8.7 pound wheels in 15 by 6.5j.
    I do not think the lugs are right for a Prius, that may be a custom order.
    SSR Wheels Wheel Lineup
    It would improve braking, handling, performance, and ride. It might improve MPG if for no other reason than your wallet being $1600 lighter.
  4. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :DToyota has done a good job fitting the Prius with high mileage wheels. Only problem, they're so UGLY. My PIP's higher mileage wheels are stacked in the garage. Go ahead, penalize me. My PIP with Prius 5 wheels, looks FAST and FUEL EFFICIENT, sitting still. Enough said.
    Chris S likes this.
  5. lizardacres
    43
    Portland, Oregon
    2024 Prius Prime
    XSE
    Yes, there are definitely wheels to lighten the wallet. Example: Rays, Super Eco 15x6", 5x100, 45 offset. About $332 each. About 9 lbs. But it kind of reminds me of old VW bug wheels. Wonder how these would impact mileage?
  6. lizardacres
    43
    Portland, Oregon
    2024 Prius Prime
    XSE
    Now for a fantasy wheel: Ray's Eco Drive 37ESPCORT in Earth Blue
    Specs: 17x7, 5x100, 50 offset and 14.3 lbs. This one is $630. Wow.
  7. joerockt
    joerockt Junior Member
    97
    27
    Enkei RFP1's in 15" I would think are lighter than the stockers.
  8. bwilson4web
    16,012
    Yes but you won't like it:
    • decrease the revolutions per mile of the front wheels and/or tires
    I did this with my NHW11 (2003) Prius by using a larger diameter tire, ~905 revs/mile to ~850 revs/mile. This has the same effect as increasing the gear ratio, permanent 'over drive.' But there are a few drawbacks:
    1. MPH indicator reads lower than true speed - this can be handle by figuring the calibration offset and mentally calculating the true speed. Easier, just to a GPS speedometer.
    2. Miles indicator reads lower than true - so the distance traveled will be off by the calibration offset.
    3. MPG indicator read lower than true - because the distance traveled measured by wheel rotations is off, the car displayed MPG will show lower than true. Just calculate the true MPG at the pump with the corrected distance.
    I went with larger diameter tires because it also improves straight-line stability. The older, 2001-03 Prius is steering neutral and almost no tracking ability even with 'perfect' four-wheel alignment. But the larger diameter, slightly heavier tires have improved highway tracking making the car less fidgety.
    The MPG improvement is slight but evident after doing the calculations. It also reduces maximum acceleration, permanent overdrive.
  9. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    Reducing Unsprung weight is the holy grail of car racing. Light wheels, brakes, & Springs will improve preformance & MPG. It will also lighten your walet for quicker acceleration & breaking. Do you really need 2-4 more MPG and at what cost? Are you Autocrossing it at SCCA events? Entered in the Green Grand Prix at Watkins Glen?
    If yes then lighten it up. My guess is that you can drop 10lbs per corner for a total of 40lbs before you attack the intake, header, & exhaust for another 40-50lbs.
  10. lizardacres
    43
    Portland, Oregon
    2024 Prius Prime
    XSE
    Maybe it's time I lose those extra 5 lbs
    Are you saying you kept the same wheel and only increased the tire diameter on the front wheels only? To what size tire? Not saying I would want to this, just trying to understand.
  11. lizardacres
    43
    Portland, Oregon
    2024 Prius Prime
    XSE
    That's a good plan and I've actually looked at those many times, but honestly, it's not my favorite style. There aren't a lot of good high mileage choices out there. A shop in Tucson stocks a JDM I've been looking at too that is perfect for our cars, but I'm not sold on the style of this one either. Too many spokes.
    Specs: 16x7 offset 48 weight 11.6 lbs, price $409
  12. joerockt
    97
    27
    Yea I don't like the RFP1's either, but as far as weight and cost goes its hard to beat them. I'm personally looking at the Motegi SP10's in 17". But its not a concern for me to lose a few mpg in the process.
  13. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    Sure they have, IF they went from the oem 17" down to a 16" or 15". Going from a 15" oem to a lighter 15" may net a small gain, but whatever you spend on wheels will buy you a lot of gas.
  14. Vas25tl
    Vas25tl Member
    268
    77
    Milwaukee
    Not worth it.
    That being said, I can't wait to put my 17's back on. My snow tires in a 15" along with cold temperatures has taken my average from 52.X to 44.X.
  15. Mendel Leisk
    40,584
    ^ Funny, our snows are 195/65R15 (Michelin X-ICE) and stock is 215/45R17 (Michelin Pilot), and they seem very close for mileage. Considering the 15" OD is bigger, the snows might even be better, since the odometer is off a bit with the snows, underestimating distance travelled.
  16. Vas25tl
    Vas25tl Member
    268
    77
    Milwaukee
    I wanted the Michelin X Ice's but got too good of a deal on the Firestone Winterforces....It's like a tractor tire - loud and obnoxious, fuel consumption took a huge hit but wow are they amazing in the snow.
    I have a set of Michelins that are going on the 17's instead of the OEM Toyo's in 3-4 weeks and getting put back on the car.
  17. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    In theory yes. In practice no.
    It's too expensive to justify. Not only do you need a very lightweight wheel but it must be aerodynamic as well (including a high offset). Most of the really light wheels appear to have horrible aerodynamic properties. What you gain from weight loss you lose in aerodynamics AND for the price difference you could purchase a lot of fuel. No one I know of has reported any quantifiable gains from lighter wheels. You're better off replacing your OE tires with something more fuel efficient and possibly taller when the time comes.
  18. mahout
    mahout Active Member
    655
    116
    NC
  19. mahout
    655
    116
    NC
    Yes, we have for our racers.
    First, unless you want to race, lighter wheels aren't worth the cost. You can use TireRack to seach the weights of wheels that fit the prissy (mostly Honda Fit and older Hondas) but the cost is high. Some wheels, as low nice person 9 lb cosdt $200 or more each. The RPF1's that weigh 9.5 lb are abot $135 each. There are wheels that are wider as well but usually don't save weight. Honda Insight, gen 1's, use a 10 lb wheel often available in salvage yards.
    And wheels with lesser offset, such as Scions, are advantageous in cornering but hard to save weight with wider rims
    Second, if you want to see higher mpg you should select tires of the less weight. Again use TireRack to search tire weights. The energy required to turn wheels with heavy tires far greater penalizes mpg than heavier wheels. Physics of torque applies.
    Most tires 175/65x15 or 195/55x16 weigh from 15 to 22 lb and yes generally the more narrow tire of similar overall diameter weigh less. If you choose to put wider tires you need to reduce diameter slightly to not play havoc with your mpg. For those of us who want our Prissy to convert into a 48 mpg sportster with lowered springs (not over 1.5" unledss you want handling diofficulties), shocks, and Dirzza ll tires, the 195/55x15 are a gift.
    Third, increasing tire diameter by wheels or tires is another losing effort except on flat level ground.The Prissy does not benefit from a reduction in axle ratio in thr real world; not enough horsepower to utilize and thus adds power required.
  20. mahout
    655
    116
    NC
    Third, increasing tire diameter, by wheels or tires, isn't effective for anything but flat level roads. Prissys just don't have enough power to prevent the consideralbe extra power required to prevent less mpg in thed real world.
