Can you install 2015 Corolla's Rims & Tires on 2015 Prius v ?
Discussion in 'Prius v Accessories and Modifications' started by yupito, Jul 14, 2015.
  1. yupito
    yupito New Member
    Miami
    2015 Prius v wagon
    I have a Prius v Two and want to upgrade the rims and thinking of buying a set of Corolla's Rims and Tires. Would they fit without issue?
  2. Mendel Leisk
    38,728
    Just a hunch, you'd be needing Camry rims.
    I believe some Prius v owners have used a Camry steel rim with snow tires. Check with an authorized Toyota service department?
  3. E46Prius
    E46Prius Active Member
    314
    219
    Costa Mesa
    ^ Why would you need to check with an "authorized" Toyota service dept.? These are just commuter cars haha. If the specs match, they match. Bolt pattern, offset, center bore size.
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    114 x 5 is the bolt pattern for the Prius v
  5. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Actually, it's 114.3 mm or 4.5 inches. ;)
  6. Mendel Leisk
    38,728
    Why not? They have the experience. And their prices aren't that outa line.
    Turned out an '06'ish Corolla steel rim was a perfect match for our 2010 Prius. A dealership set us up with rims for $70 apiece, with X-Ice, and the compatible lug nuts.
    Prius v owners here have been using a Camry steel rim on a few occasions.
  7. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    No it wouldn't fit because the Corolla's bolt pattern is 5 x 100 whereas the Prius v is 5 x 114.3 as noted.
    iPad ?
