Can you put a Prius in Neutral without turning it on?
Discussion in 'Gen 3 Prius Technical Discussion' started by Mendel Leisk, Nov 13, 2010.
  1. Mendel Leisk
    38,232
    I read the "similar threads found", and searched a bit, still stumped:
    For decades, in preparation for washing our cars, I've been shifting them into neutral without starting up, and rolling them out of the garage. Typically there's a mechanical "keep it in park" lock that needs to be bypassed. Then, once you've released the parking brake, you can open the driver's door and get your car moving in "foot mode". ;)
    I think it might be doable with the Prius, with the power button pushed but car not completely "on", with some depletion of battery, but not sure. Ideally I'd like to put it in neutral without any powering up, but I suspect that's not possible.
    Ideas?
    48,962
    why don't you just back it out in ev? the amount of energy use is negligible and the engine won't come on which is the goal, isn't it?
  3. richard schumacher
    7,663
    1,038
    United States
    You could put it in IG-ON and push it out... and then the first time you forget to turn the car OFF and drain the traction battery you will not have a good day. Exercise your brain by forgetting a decades-old habit and do as bisco suggests.
  4. Mendel Leisk
    38,232
    Just to put my experience in perspective: we've just passed 100 kms, and this our first Prius, LOL. Ok, will EV mode work with cold car?
  5. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    Absolutely. As previously said, EV will only use the electric motor and is great for moving a cold car a short distance and keeping the engine from performing an unnecessary warmup cycle.
  6. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
  7. fuzzy1
    10,043
    Not so fast. Mendel hails from the greater Vancouver area, which is essentially the same climate I have in the greater Seattle area, or even slightly cooler. Compared to your Texas, we are cold.
    My car won't go into EV mode when the coolant temperature is below 68F / 20C, which happens about 360 mornings per year. Outside of EV mode, it will back most of the way out of the garage before starting the ICE, but I cannot reliably get it all the way out.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Thats right, the car won't enter EV mode if cold < 68 degrees I believe.
    edit - like fuzzy said.
  9. Mendel Leisk
    38,232
    Ok, thanks all.
  10. bisco
    48,962
    sorry for the bad info, the aftermarket unit in my gen II works perfectly for this. i didn't know the stock unit was different.:)
  11. northwichita
    481
    102
    29
    Wichita KS
    Reading the question, I related it to the gen II
    Quote ----
    [SIZE=+1] How to leave the car in Neutral
    [/SIZE]2nd-gen is more difficult
    Electric pawl actuator, special 3-phase drive motor
    Shift to N, then pull the PCON MTR relay
    That disables Park, but the car gets unhappy
    Do what the screen says: set emergency brake
    ... then you can at least shut down
    ----from hobbits writeup -----
    Prius tech training
    relate to Gen III ?
    I've used the above on my 04 prius to move it around without having to turn on the car , this is after I pulled out the relay when the car was in neutral.
  12. Mendel Leisk
    38,232
    I assume you start with the car running, hmm:
    My scenario: cold car, early morning, want to roll it out of the garage into the driveway without start-up, and wash it. Goofy how with all this high tech it's more or less impossible, due to electronic shifter.
  13. bwilson4web
    15,392
    There seems to be about 3-4 seconds between "READY" and when the ICE starts. Perhaps:
    1. Set parking brake.
    2. Press "POWER"
    3. As soon as "READY" flashes, shift into "N" to disable ICE start
    It worked twice this evening. Personally, this seems risky as an accidental shift into gear without being in the driver seat might result in 'bad things.'
  14. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    It's been stated repeatedly - when you start a *cold* car, you have a window of time to press 'EV' where if the EV battery has 3+ bars, it will go into EV mode.
    It is a limited EV - it will only allow speeds up to like 13 MPH (or whatever), and acceleration knocks it out more easily...
  15. Mendel Leisk
    38,232
    Yeah but from other responders I gather you need fairly high ambient temp. We're around 5~10 Celsius right now, and getting colder quick.
  16. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Correct. If the temp is below 68 and the engine/battery is stone cold, it will not go into EV. That has been my experience.
  17. fuzzy1
    10,043
    It has been stated repeatedly ... by folks who live in SoCal, SoTexas, Florida, and others who live within a stone's throw of the Equator.
    For those of us living next to the home berths of Coast Guard icebreakers, this doesn't work. Our climate is too cold.
  18. fotomoto
    5,597
    3,771
    So. Texas
    OK, just for you guys I braved the horrid weather here tonight (61f on house outdoor thermometer, 63f on car).:p Car has been sitting for 4+ hours in driveway, 3 bars on battery and no parking brake.
    I was able to quickly shift into neutral after powering/starting up the car and after letting off the foot brake gravity rolled it down the entire length of the driveway and further into the street without ever starting the ICE. I even let it sit in the street for about :30secs (quiet street/no traffic) as I looked at all the warning lights and messages.
    I had to "reboot" to get it into D and the electric motor powered it back up the driveway but the ICE came on just as I was about to stop.
    Maybe the battery was still above 68f? Air temp was about 72f when it was parked about 4 hours earlier.
    FWIW
  19. fuzzy1
    10,043
    ^^ I don't see you mention pressing the EV button. The 68F cutoff doesn't apply to N.
  20. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    Maybe you guys from the great white north could put a heater in your garage to raise the ambient temp... Also, who washes their car when it's below 40 degrees outside? :eek:
