can you replace 86T with 88H?
Discussion in 'Gen 2 Prius Main Forum' started by k1ngn0thing, May 4, 2019.
Tags:
  1. k1ngn0thing
    k1ngn0thing Member
    205
    49
    MA
    2016 Prius c
    I'm looking to replace my goodyear comforted touring p185/65R15 86T with 185/65R15 88H
    but am not sure how to confirm they fit as I'm not sure what all the measurements they're asking for mean. I also find it hard to believe that a tire this cheap can be so highly rated.
  2. ChapmanF
    15,697
    86 and 88 are the load index, T and H are the speed rating. H is a higher speed rating than T (it's a weird code, Google helps), so you're good there.
    Comparing apples and apples, 88 is a higher load index than 86, so that would be ok too. But, if you really meant the one size starts with a P and the other doesn't, these are not apples and apples.
    The sizes that start with P are standardized according to the "P-metric" system overseen by the Tire and Rim Association. Sizes without P follow "Euro-metric" standards overseen by the European Tire and Rim Technical Organisation.
    Both systems have the idea of a "load index", but it works completely differently in the two systems. More information here.
    So, if you're comparing a P-metric load index 86 to a Euro-metric load index 88, you would really have to look both up and see how many pounds load capacity each one corresponds to for that tire size. (The same P-metric load index number means different load capacities for different tire sizes. Euro-metric load index numbers don't.)
    Clear as mud? :)
    strawbrad, SFO and k1ngn0thing like this.
