Can you replace physical button on each side of display?
Discussion in 'Generation 1 Prius Discussion' started by dpeverhart, May 13, 2014.
  1. dpeverhart
    dpeverhart Member
    126
    23
    I
    I am referring to the 'Info', 'Audi', 'Display' and 'Climate' buttons on each side of the MFD. Some are badly worn and I was wondering if they can be removed and replaced.
    Thanks
    David
  2. JC91006
    16,673
    8,518
    This question was just asked the other day. You can contact autobeyours.com and get the parts. They cost $25 each button and they can be replaced individually.
  3. ChapmanF
    17,347
    If you look on this diagram, do you mean the buttons shown as "set #2" and "set #3" (three buttons each)? Looks like you'd spend less than $40 to get both complete sets dealer new.
    -Chap
  4. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    728
    Boulder Hybids, Boulder, CO
    Are you asking for buttons for Gen1 or Gen2 Prius? Gen2 are easy to change out. Gen1 requires removing the center dash panel which often results in the panel disintegrating as you try and remove it.
