Can you run a gen 3 (2012) on a bad HV battery?
Discussion in 'Gen 3 Prius Technical Discussion' started by Banksy, Jan 16, 2021.
  1. Banksy
    Banksy Active Member
    415
    132
    Lancaster Pennsylvania
    I have a 2012 that I can get cheap
    Dirt cheap
    It's located about 7 hrs away from me
    Owner said he drove it for a month without the battery working properly
    I'm highly considering buying said dirty cheap prius and driving it almost 7 hrs back home and swapping out the pack with a OEM toyota pack
    I'm curious if you can run the car like that if it will put so much strain on the engine that it'll cause damage
    Any input?
    mikey_t likes this.
  2. ChapmanF
    17,928
    It would be worth getting more details about what the battery issue is.
    There's unlikely to be any damage to the engine whatever happens. Of more concern is just that the battery may reach a point where the car's computers say "nope, not doing that anymore", and if that point comes 3.5 hours into your 7 hour drive it may throw a bit of a wrench into your travel planning.
  3. ASRDogman
    ASRDogman Senior Member
    7,493
    3,882
    Why not bring the replacement pack with your and change it? It would be safer. And doubtfull
    you'd get stranded. If you have AAA with unlimited towing mileage, don't worry about it. :)
    tre4xw30 likes this.
  4. PriusCamper
    PriusCamper Senior Member
    12,555
    5,085
    Pacific Northwest, USA
    The HV battery starts the engine... So if there's still life left in it it's possible... But if battery if HV battery is dead, so is the car.
  5. Banksy
    415
    132
    So it's essentially the same as a gen 2
    Gotcha
  6. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    If it's dirt cheap and otherwise in good shape I think it's a good buy, especially if you're going to do a lot of maintenence on your own. I'd clean the EGR circuit and change all the fluids. I'd just drive it as easy as possible on the way home.
  7. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    o_O
  8. Banksy
    415
    132
    Wait... this is a thing?
    I thought 200 miles was the max
    Link? I was going to spend about 600 on a uhaul between gas and fees.
    This would be incredible
  9. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "Wait... this is a thing?"
    Definitely, as long as you've brought along all of the required tools and know what you're doing...
  10. Banksy
    415
    132
    No the unlimited miles for towing
  11. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    I'd run Dr. Prius app (connected by bluetooth to an OBDII adapter) to see what codes show up, then clear the codes. Sounds like the owner was freaked out by early battery problems. If you clear the codes, you probably can drive it to your place. Probably, of course, is not certainly.
    mikey_t likes this.
  12. Banksy
    415
    132
    For whatever reason Dr prius never worked on my old phone
    Id assumed it was my Bluetooth OBD 2 reader
    Will this OBD2 reader work with Dr prius?
    #12 Banksy, Jan 17, 2021
  13. royrose
    1,389
    953
    Foot of Pikes Peak
    I don't know that one. I use the OBDLink Lx (with my android phone). It is more expensive at about $50.
    I got the OBDLink LX because Hybrid assistant recommends it. Dr. Prius tested the MX (supposed to work with IOS and android), didn't like it, didn't test the LX which is android only.
    #13 royrose, Jan 17, 2021
  14. Ed Beaty
    334
    311
    Salt Lake City
  15. PriusCamper
    12,555
    5,085
  16. ASRDogman
    7,493
    3,882
    You know, the 12v battery could be weak, or bad.... It will cause problems with the hybrid battery lights...
  17. ASRDogman
    7,493
    3,882
    If you pay the extra money for the year, for AAA, you can get unlimited mileage towing...
  18. Banksy
    415
    132
    How much is that?
  19. ASRDogman
    7,493
    3,882
    I have no idea. But you can go to there site and find out..
