can you see my new website yet?
Discussion in 'Fred's House of Pancakes' started by john1701a, Mar 16, 2004.
  1. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    DNS is in the process of propagating with the new Name-Server information now.
    That means one of three things... either you still see the old website, you see nothing at all (eek!), or you finally get to see the new website.
    The "New photos from last Fall" are only available on the new (which is a faster website with much more bandwidth).
    Please let me know what your status is... especially if something breaks as a result of the switch over. (Thanks!)
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Just the old one for me....updated 3/11
  3. Dave
    Dave New Member
    340
    Santa Cruz, CA
  4. gene
    gene Member
    98
    NH
    John,
    According to both domain name servers for john1701a.com (as listed in whois), the IP address for your site is 65.18.201.68. This server still shows what I assume is the "old" information.
    The timeouts on the DNS records look to be just under 3 hours, so it really shouldn't take much longer than that for any changes to propogate -- once they are made.
    Or did you change registrars (from CORE to someone else) and you're waiting for the domain to transfer to the new registrar (and/or new nameservers)?
    Gene
    P.S. If you have no clue what I'm talking about, let me know and I'll provide more details in "English."
  5. john1701a
    12,754
    5,245
    57
    I'm with the same registrar, all that changed was the name-server.
    This is the same thing I had to do last September with my previous upgrade. The behavior then was odd. It was hit or miss for about a day. Sometimes I'd see the new site, sometimes the old.
    I've been monitoring 6 different whois providers. The count showing the new info is now up to 3. So it's slowly getting there.
    Unforunately, when I ping, the old IP is still being returned. So I can't even see my own website directly yet. (I can cheat though, by using a pass-through URL.)
    Anywho, patience is wearing thin. I've been looking forward to this for awhile and wonder if I set everything up correctly...
  6. daniel
    14,487
    1,518
    Spokane, WA
    5:44 p.m. on Tuesday and I get the old site.
  7. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    Old site here.
  8. Davack
    Davack New Member
    Philadelphia area
    It's 9 pm ET on Tues (3/16) and I get your *new* site (with New Fall Pictures).
    David
  9. Dave
    Dave New Member
    340
    Santa Cruz, CA
    I just tried again, I got the 3/11 last update site, then I hit refresh, and got the 3/14 update.
  10. efusco
    19,891
    1,192
    Nixa, MO
    Me too, got 3/14 at home...
  11. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Last updated Sunday 3 14 2k4 as of this evening at 7:45PM Pacific Std time.
  12. gene
    gene Member
    98
    NH
    Minor note:
    http://john1701a.com/
    works, but:
    http://www.john1701a.com/
    doesn't seem to be pointed to the virtual server at this time. So if you're having trouble at this point, make sure you're not adding the www to the beginning of the URL.
  13. aja2460
    aja2460 Junior Member
    27
    Woodinville, WA
    I see the one dated 3/14
  14. daniel
    14,487
    1,518
    Spokane, WA
    I get the same behavior as noted above. I have updated my favorites accordingly.
  15. dismack
    dismack Junior Member
    New Jersey
    Four Touring
    Forwhatever reason, tring to get to both sites now is sending my security setting crazy.
  16. john1701a
    12,754
    5,245
    57
    "www" will not show my website anymore. After 2.5 years of having to deal with that undesired alternate, it has been permanently disabled.
    http://john1701a.com is what everyone must use now. If it is showing a prompt of some sort, I'm baffled. None of the 5 computers (4 different versions of Windows) have exhibited that. And without any detail whatsoever, there is no way to debug. My guess is that it is actually a temporary brower/server cache problem that will self-correct after the switch-over is finally complete. If not, I need more info from you...
  17. jkash
    jkash Member
    889
    West Hills, CA
    John,
    I refreshed my browser (Safari) as well as deleted the cache. I still see the last update as Sunday, March 14th. The same page loads using IE as well.
    Jeff
  18. mastersgtbob
    mastersgtbob New Member
    it's 10:42 and i see 3/14
  19. tag
    tag Senior Member
    2,526
    Chicago
    Thursday morning and I see 3/18.
    When I type "www.john1701a.com" into the address line (IE6), I am redirected to
    "https://www.john1701a.com:19638/webhost/rollout/site".
    FWIW
  20. jkash
    jkash Member
    889
    West Hills, CA
    It's up John. The page now says updated the 18th. You are back in business.
    Jeff
