Can you set it so the display does'nt change when you change drive modes?
Discussion in 'Gen 3 Prius Main Forum' started by SoShoreKen, Aug 29, 2016.
  1. SoShoreKen
    SoShoreKen Junior Member
    South Shore MA
    I like to have my display on the engine flow. but when I switch from eco mode to power mode it changes. Then I have to change it back. Is there a way to set it so it does'nt change?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    I do not think so.
    I know that when you switch to ECO mode that the display will switch to the ECO display. I did not know that when you switch to Power mode that the display will switch displays. I will have to try this.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    I'm going to have to experiment with that too...
    Of course I don't usually have mine set on engine flow, nor do I use power mode very often.
    But I'm going to give it a try and see if my display changes.
  4. FinToy
    FinToy Active Member
    145
    141
    Finland
    At least in European models there is no change in display, no matter what driving mode I choose.
    Just being curious, can you post photos how does it change? Thanks!
  5. Mendel Leisk
    40,586
    I use only the Hybrid Synergy Indicator, and I don't recall the display changing with mode change. OTOH, it's been on nothing but Normal mode for about 5 years. I'll check it out.
  6. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Mine does. If you go to ECO mode while driving, the HSI changes to the power bar.
