Can you set turn signals to 4 blinks with light press?
Discussion in 'Gen 5 Prius Technical Discussion' started by Jon Watkins, Sep 21, 2024 at 4:01 PM.
  1. Jon Watkins
    Jon Watkins Active Member
    124
    113
    Bluffton SC
    24 LE. Picked the car up Tuesday and it gives 3 turn signal blinks with light turn signal press. I’d like it to blink the turn signals 4 times with a light press. My 17 came with 3 blinks and I had to have the dealership hook it to their service computer to change it to 4 blinks. I can’t find anything about doing this in the 24 LE manual? Does anyone know how, or if, I can change this?
  2. KMO
    KMO Senior Member
    1,644
    462
    Finland
    2023 Prius Prime
    It can be changed the same way, despite being missed in the manual.
  3. Jon Watkins
    124
    113
    Bluffton SC
    Do you know what it’s called in the computer? When I had it changed on my 17 I had to talk the tech through it because he was clueless.
  4. Hammersmith
    Hammersmith Senior Member
    1,507
    1,514
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Customize Meter/Gauge System
    Lane Change Flashing Times Adjust
    Can be set to: Off, 3, 4, 5, 6 ,7
    soft_r likes this.
  5. soft_r
    soft_r Junior Member
    84
    62
    Beverly Hills
    2024 Prius
    Super useful, gonna get them to disable it in mine because when I cancel my turn signal manually sometimes i overdo it and trigger the temp flash. Makes it look like I don't know if I wanna go left or right lol
  6. Jon Watkins
    124
    113
    Bluffton SC
    thanks!
  7. Roy Peterson
    Roy Peterson Junior Member
    33
    38
    Richland WA
    2024 Prius Prime
    My scan tool allows me to customize this feature. I set mine at 5. Plus you can change the flasher volume. I set mine to max since I have hearing loss and don’t always wear my hearing aids
    Cheers
  8. RRxing
    RRxing Senior Member
    2,521
    1,793
    NEPA
    Carista allows you to change this and many other functions (changed my Venza to 5 flashes.) No dealer visit required.
    soft_r likes this.
