Can you sleep in your Prius Prime and use the AC all night without using the engine?
Discussion in 'Prime Main Forum (2017-2022)' started by Caedin8, Jul 23, 2021.
  1. Caedin8
    Caedin8 New Member
    Houston, TX
    I saw that if you leave it in ACESSORY mode for 1 hour it'll shut off.
    I am wondering if I drive out to my camp site using the HV mode to keep a full 100% battery, can I sleep in the car and get AC all night without kicking on the engine?
  2. Salamander_King
    Salamander_King Senior Member
    11,013
    8,942
    New England
    Yes, if you keep it on READY mode, then until the traction battery runs out you can keep AC. Don't use the ACESSORY mode, you will drain the 12v battery very quickly. If the traction battery depletes, then the engine will come on.
    AldoON likes this.
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Your 2021 Prime probably has the auto-shutoff feature, which will need to be disabled or it won't stay in "Ready" mode all night.
  4. Salamander_King
    11,013
    8,942
    New England
    Is that a new feature in the 2021 model? I have not come across it in the manual, but now come to think of it there was a discussion about the "cabin mode" or something in Rav4 Prime.
  5. bisco
    51,719
    even if you can disable the shutoff feature, a/c depletes the battery in less than an hour. then your engine is going to go on and off all night long.
  6. ChapmanF
    17,928
    The A/C is variable speed and power, over a big wide range: it can be over 2,000 watts running flat out, closer to 200 watts (a tenth!) at minimum speed, and at lower demand than that, it can cycle on and off. So the overnight temperature and humidity (and the climate setting) can make a big difference in how long the battery carries the load.
