Can You Start a Prius c Without Its Fob?
Discussion in 'Prius c Main Forum' started by Ernie Cheng, Jul 16, 2020.
  1. Ernie Cheng
    Ernie Cheng New Member
    Phoenix
    Key on Prius C. Can you start it if it s lost and get a new key cut
    Emergency start a Rius C
    I lost key to my Prius C can it be emergency start. It with a steel key
    #1 Ernie Cheng, Jul 16, 2020
    51,155
    no. if you don't have any fobs, you have to tow it to a dealer. gonna be 'expensive
  3. Elektroingenieur
    2,515
    3,277
    Three Touring
    Many locksmiths—or anyone else who can use the restricted Smart Code Reset feature of a Toyota Techstream diagnostic system—could also fix this problem, without having the car towed or involving a Toyota dealer.
  4. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    Does it matter that the c Two uses plain steel keys and is not equipped with pushbutton start?
    I'm recalling a thread with a discussion about whether this trim of the c actually had an immobilizer or not.
    Elektroingenieur likes this.
  5. Elektroingenieur
    2,515
    3,277
    Three Touring
    That’s a good point. In that case, you wouldn’t even need the Techstream system, much less a dealer—just a locksmith.
  6. ChapmanF
    17,347
    Prius Gen 1 had no pushbutton start and came with a key that you turned, but the key still had a chip in the head.
    Is the c Two "plain steel" key really a plain steel key?
  7. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    I'm not finding it right this second, but there was a thread where this came up. A c owner had the key copied (mechanically) and made no effort to deal with the possibility of an RFID element in the original key, yet the car operated normally when used with the duplicate key.
    However, the owners' manual clearly describes the existence of an immobilizer system. I don't recall that we got to the bottom of it.
    I'll append a link to this post if I can find that thread within the edit window...
  8. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
  9. bisco
    51,155
    come join in the fun ernie
  10. noname87
    noname87 Junior Member
    84
    NC
    I just had metal keys cut for my Daughter's 2015 Prius C One using the valet key. Lowes checked and it did not have a chip. I tested it and it started the car. I have not done a test drive yet.
  11. bisco
    51,155
    that settles it then
