Can you tell me what package this is?
Discussion in 'Gen 2 Prius Main Forum' started by HSDP, Dec 27, 2007.
  1. HSDP
    HSDP New Member
    36
    MA
    Is there a way to tell what package a prius has by VIN #? Specifically I am looking at this car:
    JTDKB20U063154250
    Can anyone help me?
    Thanks in advance.
  2. Tideland Prius
    16,195
    Looks like a 2006 with side airbags. That's all I can tell.
  3. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Go to:
    http://www.decodethis.com/
    or type in "VIN codes" in Google. Also, most car insurance companies have decoders on there web site. Just be aware that you may be putting out your or someones personnel info if the VIN can be linked to a buyer. (e.g. next time leave the last digits off).
  4. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    As far as I know the option package is not encoded in the VIN. Have you asked a Toyota dealer?
  5. Godiva
    Godiva AmeriKan Citizen
    10,339
    Ask about the car:
    What year?
    1 cd or 6 cd changer.
    Cloth or leather. (although that isn't always reliable with after market)
    VSC.
    Homelink.
    Smartkey.
    A lot of these answers can indicate what package it is. Also, what state it was sold in if the owner/seller knows. Certain packages are more common in certain states.
    I don't think a VIN will tell you any of this.
  6. Tideland Prius
    16,195
    The VIN gives the year as I've said above.
  7. Tideland Prius
    16,195
    It's a 2006 NL Package.
    Here are my clues:
    Our own Knowledge Base has a Prius Standard Features and Optional Equipment thread
    and pictures here show navigation buttons and no leather
  8. skguh
    skguh Member
    195
    Montgomery, Alabama
  9. Tideland Prius
    16,195
    Re: Actual Answer
    Like I said in the 2nd post, the VIN only tells me the year and whether it has side airbags or not. Of course JTD is Japan, Toyota, Tahara plant and so forth. But otherwise yes, you can't tell the package that's why I had to dig a little deeper.
  10. HSDP
    HSDP New Member
    36
    MA
    Thanks guys. This VIN# was used by an insurance company as a "comp" car so they could justify the price they are giving me on my 2006 Prius that was totalled in a car wreck. I was trying to find out the package because they do not say what the "comparable" cars they are using have. They don't believe in book value, they just use their own market analysis and the more I look at it they more I see flaws in their methods. I am unhappy as this prius was a mint condition dealer serviced car and they don't even consider the options like bluetooth to "add any value" as they told me. I spent $500 on a set of new Michellin Hydroedges at costco 2 weeks before the accident and they are trying to tell me they were 50% worn. I don't know how someone can wear 50% of a tire in 2 weeks. The nubs were still on them. After going back and forth they offered me a little over $100 for the set. The appraiser also said there were minor "dings" on the car. He must have ESP or something because the car was hit on 3 sides by multiple cars and looked like a foiled up ball of metal afterwards. Through all this, he found "dings", and somehow knew that these dings were "pre-accident" dings. This car was always garaged, cleaned, waxed, and kept mint.
    The accident happened because someone else ran a stop sign, and after being with this insurance company for years I feel I am getting the shaft. Everything is a fight with them. :mad:
    I am just trying to get what the car was worth. I already bought an 08 Prius. Toyota motor was kind enough to give me $500 after I told them about my accident. They are sending a check. I wish insurance companies worked the same way.
  11. C.RICKEY HIROSE
    210
    S.F. BAY AREA CALIFORNIA
    Here it is:
    Model Number: 1224A Serial # : 63154250
    Model Description: 4-DR GAS/ELEC Category ..........: H
    Year ............: 2006 Selling Dealer ....: 20048
    Interior Color ..: FE11 Ship Date .........: 02/28/2006
    Exterior Color ..: 0040 Retail Date .......: 03/17/2006
    Body ............: HYBRID GAS/ELEC SDN Date of First Use .: 03/17/2006
    Number of Cyl ...: 4 Fleet .............: NON-FLEET
    Engine Number ...: 1NZU025178
    VIN .............: JTDKB20U063154250
    Ignition Key.....: N/A
    Accessories .....: FE NL Z1+
    Retail Dealer
    Vehicle Base Model ....................: $ 21725.00 $ 19138.00
    Total Accessories .....................: $ 5994.00 $ 4861.00
    MECHANICAL & PERFORMANCE
    Hybrid Synergy Drive System
    1.5L 4Cyl DOHC 16 Valve w/VVT-i SFI Eng
    Elctrnic Cntinusly Variable Trans (ECVT)
    Electronic Power Steering System
    MacPherson Strut Front Suspension
    Torsion Beam Rear Suspension
    15" Alloy Wheels w/P185/65R15 Tires
    Front Disc (14") and Rear Drum Brakes
    SAFETY
    Dr & Fr Pass Advanced Front Airbag (SRS)
    Traction Control (TRAC)
    ABS w/Elec Brake Force Dist & Brk Assist
    3 Point Seatbelts w/ALR/ELR Pass Belts
    Side-Impact Door Beams
    Rr-Seat Child Restraint Systm(CRS) Lower
    Anchors & Top Tether Brackets (LATCH)
    Direct Tire Pressure Monitoring System
    EXTERIOR
    Multi-Reflectr Halogn Auto-Off Headlamps
    Dual Clr-Keyd Pwr Heated Outside Mirrors
    Chrome-Type Finish on Front Grille
    Rear Spoiler
    COMFORT & CONVENIENCE
    Auto Climate Control w/Air Filtration
    AM/FM CD with 6 Speakers
    Push Button Start
    Remote Keyless Entry & Engine Imobilizer
    Cruise Control
    Liquid-Crystal Multi-Info Display Panel
    w/Energy Monitor, Fuel Consumption,
    Climate Control,O/S Temp & Audio Status
    Tilt Steer Wheel w/Climate & Audio Cntrl
    60/40 Split Fold-Flat Rear Seat
    Variable Front & Intermittent Rr Wipers
    Heavy-Duty Rr Window Defogger w/Timer
    Pwr Door Locks & Wndws w/Dr Auto Up/Down
    Adjustable Front Shoulder Belt Anchors
    Cntr Console & Dual-Compartmnt Glove Box
    2 Auxiliary 12V Power Outlets
    Cargo Tonneau Cover & Undr-Floor Storage
    Overhead Console w/Map Lights
    Fabric Cloth Seats
    Retail Dealer Total
    Vehicle Base Model ..........................: $ 21725.00 $ 19138.00 $ 21725
    50 State Emissions .........................
    Package #7 Includes: Voice-Activated DVD ... 5730.00 4692.00
    GPS Navigation System; JBL AM/FM 6-Disc ....
    CD Changer w/9 Speakers, Aux Audio Jack, ...
    MP3/WMA Playback Capability, and ...........
    Hands-Free Phone Capability via Bluetooth; .
    Rear Backup Camera; Vehicle Stability ......
    Control; Driver and Front Passenger ........
    Front Seat-Mounted Side Airbags; Front-and .
    Rear Side Curtain Airbags; Smart Key .......
    System; Anti-Theft System; Auto-Dimming ....
    Rearview Mirror with HomeLink; High ........
    Intensity Discharge (HID) Headlamps; .......
    Integrated Fog Lamps .......................
    Preferred Accessory Package ................ 264.00 169.00
    Total Accessories ...........................: $ 5994.00 $ 4861.00 $ 5994.00
    Total ..................Invoice $ 23999.00 - Msrp $ 27719.00
