Can you use window cleaner inside rear window?
Discussion in 'Gen 2 Prius Main Forum' started by Wavelene, Nov 15, 2008.
  1. Wavelene
    Wavelene Junior Member
    22
    Houston, Texas
    Is it okay to use a window cleaner such as Invisible Glass to clean the inside of the rear window? I've had my '09 Prius for a month now and have resisted the temptation to clean the interior of the rear window because page 346 of the '09 manual cautions that a glass cleaner shouldn't be used on the interior rear window because it may damage the defrost/heating element. They suggest using only water and a rag, which doesn't seem like it would do much good. Just wanted to see what other folks have done. Thanks.
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    I would avoid the cleaners that contain sodium hydroxide or acetic acid (vinegar), such as the spray foam types. Something like "Windex" would be fine. It uses detergent. Or just mix your own. 50% distilled water and 50% isopropyl alcohol with a drop of dish detergent works very well. Do be very careful when wiping. The rag/sponge can catch very easily on the heater contacts and tear them off the window. Wipe in the direction of the lines (side to side).
  3. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    spend the money and tint the entire rear and then you can use anything!
  4. Patrick Wong
    18,210
    6,513
    I have Windex, but have found that it can leave residue on the glass. So sometimes I just use a paper towel dampened with water to clean the glass and another paper towel to dry, and that usually works well.
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    invisible glass. I've never had a problem. i clean it pretty often.. plus construction material has ran into that window a lot of times... no damage to the defrost coils.
  6. tochatihu
    tochatihu Senior Member
    9,852
    3,814
    Kunming Yunnan China
    2001 Prius
    If you do break one of those 'wires' the symptom would be no defogging along that line. Remember which line it is, then go to the auto parts store and get a little bottle of the paint-on repair stuff. It actually works. My experience was not on a Prius, but it should be the same material.
  7. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    Windex should be fine, but the recommended Invisible Glass is also a grear product. I have both in my collection of cleaners. Just make sure when you wipe, go Horizontally with the lines of the heating element to prevent damage.
    Have fun cleaning.
  8. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    invisible glass is "da" bomb.
    best glass cleaner I ve ever used, picked some up a few months ago. Beats all the others.
    if you use a window cleaner just make sure it's ammonia free on tint
  9. richard schumacher
    7,666
    1,047
    United States
    Using Windex a dozen times in four years hasn't damaged mine.
  10. Wavelene
    22
    Houston, Texas
    Thanks to everyone for your input. Sounds like folks have suffered no damage from Windex and Invisible Glass products so I'll give one of them a try with a soft microfiber cloth using horizontal motion.
  11. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I've used Invisible Glass on my 2004 Prius all along, with no issues. Also use it on my FJ Cruiser. Instead of paper towels, I use a bath towel that I've "demoted" to window cleaning duty. I launder it with the other whites, whenever I clean the windows
    The combination of Invisible Glass and a cotton terry towel results in truly clear glass. I've had passengers comment on it
  12. xsmatt81
    522
    Vegas
    yeah because the new Windex formula is ammonia free.
    get the store brand with strong ammonia in it. It wont hurt the tint right away, but will eventually.
