Canadian 2008 Prius - Rear disc brakes?
Discussion in 'Gen 2 Prius Main Forum' started by grand total, Sep 25, 2007.
  1. grand total
    grand total Member
    154
    ON, Canada
    The Canadian 2008 Prius e-brochure shows a Prius with rear disc brakes on the front cover. I suspect that this is not a Canadian spec car because it does not show a keyhole on the driver's door, but it's going to be interesting to see whether my car arrives with rear discs.
  2. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    <div class='quotetop'>QUOTE(Grand Total @ Sep 25 2007, 05:41 PM) [snapback]517681[/snapback]</div>
    I looked at your brochure (link) and did a detailed examination of the specifications on P. 15 and it says --- Power-Assisted, Ventilated Front/Rear Drums. Yesterday on the Toyota web site (U.S.) I looked at a Prius and based upon the options I wanted, the electronic brochure had the following specifications --- Power-assisted ventilated front disc/rear drum with Anti-lock Brake System (ABS).
    Regards,
    Keith :unsure:
  3. Boo
    Boo Boola Boola Member
    5,051
    485
    97
    Flushing, NY
    Speaking of the specs in the brochure, what's up with the estimated mpg of 71/67/69? Are the Canadian mpg test standards that much different than the US EPA's? Or is the Canadian "gallon" different than the US "gallon"?
  4. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    Hm.. Maybe in Canada it's kilometer per litre rather than miles per gallon?
  5. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    <div class='quotetop'>QUOTE(Boo @ 2007 09 25 18:15) [snapback]517693[/snapback]</div>
    Haven't you heard? The air's thinner up here, so cars slip through the air more easily. :rolleyes:
    Yes, the gallons are different. The US gallon is about 3.8 litres, and the 'Canadian' Imperial gallon is closer to 4.5 litres. Not everything's bigger in Texas. :)
  6. Boo
    5,051
    485
    97
    Flushing, NY
    <div class='quotetop'>QUOTE(JustLurkin @ Sep 25 2007, 09:56 PM) [snapback]517704[/snapback]</div>
    No they state fuel consumption both ways - 4.2/4.0/4.1 kilometers per litre [EDIT/CORRECTION: litres per 100 kilometers] and 71/67/69 miles per gallon.
    <div class='quotetop'>QUOTE(hyo silver @ Sep 25 2007, 09:58 PM) [snapback]517705[/snapback]</div>
    Thanks. That's what I thought. But I didn't previously know that Canada used the Imperial Gallon measure.
  7. Frank Hudon
    Frank Hudon Senior Member
    4,147
    City, Hiway, Combined MPG
  8. Tideland Prius
    16,195
    Nope, we get rear drums, even with the new "Special Edition"
    <div class='quotetop'>QUOTE(Boo @ Sep 25 2007, 06:15 PM) [snapback]517693[/snapback]</div>
    Yeah that's imperial gallons.
    so if you think 4.6L/100km (51mpg) combined is hard, we have 4.2L/100km (57mpg) combined to match. Actually, your 51mpg is even worse than the 52mpg (4.5L/100km) combined rating in Europe.
