Canadian gen 2 owners - routine maintenance costs at dealer?
Discussion in 'Newbie Forum' started by Echoezra, Apr 12, 2013.
  1. Echoezra
    Echoezra Junior Member
    42
    Hi there,
    I'm new here, and considering purchasing a gen 2 prius, i've been peeking in for a little while and was first looking into a 2010, but that's been sold, so now im starting the research over on gen 2 specifics, focused primarily on 2009 model, as it looks like there's one available at my local dealer.
    Any concerns particular to that gen/2009 model would be appreciated.
    (Is that the one with the troublesome, expensive headlights, for example?)
    I see lot of posts saying "no major repairs, just routine maintenance" and I've seen some posts describing this or that and recommended mileage points, but I'm getting a bit confused jumping around between threads and so i'm trying to organize all the info I need into one spot as I'm getting confused with going back and forth to my converter changing miles to Kms for starters, lol. My memory is bad that way, I need to see it all in one spot. :(
    Also, I really need some kind of estimate as to what each of these repairs would probably run me to have done at the dealer or other shop if applicable (not toyota/prius specific). I'm not mechanically inclined and i dont generally order things online.
    In Canada prices, preferably, that's why I mentioned Canadian owners in particular, but anyone who can provide me input would be great, and just note if you're talking US prices, ok? Thanks.
    49,542
    09 was a good year. how many km on her?
  3. Echoezra
    42
    Thanks for the reply. :)
    I think it said about 88,000 km
  4. Tideland Prius
    16,160
    No worries about headlights since HIDs were never offered in Canada, just regular halogens. Just make sure that the vehicle has been looked over by a qualified Hybrid Technician at the dealership (or if it's Hybrid CPO, even better). You'll have about 70,000km left on the hybrid warranty (it's warranted for 8 years/160,000km from the In Service Date).
    I would sit in the car and turn on the headlights and see how they perform to check the strength of the 12V battery. I've had a weak battery (the original one in our '05) and it still "checked out" when I took it into the dealership :rolleyes:. Of course it did because they tested it while the car was running so the 12V was charging. Anyway, just make sure it's up to snuff as the 12V would be 4-5 years old and may need replacing soon (~$200 at the dealer). The 12V is the one that runs your accessories like radio and headlights.
    The Hybrid Transaxle Fluid (i.e. transmission fluid in a regular automatic) will need changing at 96,000km (so your next service if the 88,000km oil change has been done).
    Check toyota.ca --> For Owners --> Service Your Vehicle --> Maintenance Menu and plug in the details (2009 Prius with 88,000km) to see the maintenance schedule (click the Full Schedule tab at the top if you wanna see the details for other service intervals).
  5. Echoezra
    42
    Thank you do much for the reply.
    Good news to hear about the headlights.
    Now about testing battery strength by turning on the lights, it will be hard to tell since it will be daylight when I'm test driving.
    What else I should be looking for when testing this out? Literally, if you could walk me through everything, haha, I've never driven a prius before, I sat in one once when it was off. Lol.
  6. Red09
    Red09 Junior Member
    57
    26
    Creston, BC
    2013 Prius Plug-in
    Technology
    Was at the dealer yesterday and bought the oil and washers to replace my transaxle oil and it cost $50 for the oil and $9.00 for the washers. Directed my son through the oil change and paid him $20. I had my iPad out looking through all the pictures of how to do it from this forum.
  7. Tideland Prius
    16,160
    Well if the battery is low, you'll see the dashboard lights start dimming (including the "taillight on" light or the "AUTO A/C" light if the climate control is running). You may even see the master warning light which is a giant red triangle with an exclamation mark in the middle.
    Make sure there are no strange high pitch sounds from the engine compartment. There will be a buzz (that's just the brake actuator) and if you start the car, there will be a sound from the driver's side and that's the coolant pump pumping coolant from the thermos to the engine to warm it up (unless it's the car has been sitting around for > 3 days, at which point the coolant in the thermos will be the same temp as the rest of the coolant anyway so the pump won't start up).
    Just like any other car, listen for rattles or weird thunks.
    The car did come with a cargo net, wheel locks and tonneau cover as standard equipment so make sure they're there and the dealer didn't take it away. Check for wear in the rear wiper since that probably wasn't used very often and may not have been changed (if it's cracked or showing signs of wear). Same for front wipers.
    It may or may not have the accelerator pedal shortened (it was all under the "recall" because of that unintended acceleration scare). So if it hasn't, they'll probably ask you to take it in (after you've bought it) to get it fixed. It should be free of charge and covered under the "recall".
    And of course check the service history of the car. Ask them to show you it's been serviced properly with all the proper items and check it against the one online.
  8. Echoezra
    42
    Thank so much again. I do have a couple more questions if you can bear with me :)
    Now that headlight test with the car off - that should give me a starting indication of the battery weakness.
    But supposing I didn't walk out to the parked car... Supposing somebody had started it up and "brought it over", either a couple minutes beforehand, or an hour earlier or a day earlier or whatever, how would that affect things as far as judging the 12v state? The dealer I deal with, the car isn't at her lot, it's at another dealer run by their parent company. We may drive over together, but if they know we're coming they may start it up to get it "ready", right? I've also had them bring an Insight over to her lot. That then needed to be jump started. And found out it was jump started to get it over there too. Lol.
    How are the 12v batteries as far as when the car is running? I'm thinking in terms of charging small electronics, phones, etc. we're always plugging things in in my preset car, is that bad considering how sensitive the prius 12v seem to be?
    Also, could anyone walk me through the proper starting stages (what means on, acc, start, etc) and the proper shut down procedures with these fancy push button dealies? Lol. I feel like a fool asking, but I also don't want to screw something up by accidentally leaving it on incorrectly if I do intend to buy it, and I know if the engine isnt running I'm likely to get confused. I've read little snippets about people not realizing their car wasnt off properly, or the key causing a battery drain or such things. I want to know exactly what steps to do or not do.
    Thanks so much again you guys!
    I hope after all this I actually get to buy one. :)
  9. Tideland Prius
    16,160
    Well if the 12V battery is weak, it shouldn't matter if they drive it over. Just shut off the car, wait a few secs, turn on the lights and see how it performs. Leave it on for a minute. If the battery is strong, it won't drain it in a minute but if the lights start dimming (just walk to the front of the car) or the radio starts sputtering or it gives you warning lights, then you know it's weak.
    I'd be wary of that Insight then. If it had to be jump started, twice, the 12V battery's life is already shortened. Also, it means they didn't bother to take care of the car (so how has the HV battery been taken care then? If the car wasn't driven, the HV battery would've been drained too).
    If the car's running, charging is fine. 120W total is what is listed on the 12V outlet cover (that includes both outlets).
    If your foot is off the brake:
    Press the POWER button once --> ACC. This is Accessory mode (like turning the key once in a regular car or turning the key counter-clockwise in a GM car). This runs the radio
    Press once more --> IG-ON. This is "ON" (like turning the key twice in a regular car or turning the key once clockwise in a GM car). This powers on the radio, climate control (fan), power windows and power mirrors.
    Press once more --> OFF. The car is off.
    In any circumstance (OFF, ACC or IG-ON), if you press the POWER button with the brake pedal depressed, the car will go to READY (or "start" in a regular car) and the car is live and powered.
    To shut off if the car is NOT running, just keep pressing POWER and cycle through the stages above until it's OFF.
    To shut the car off if IT IS running, press the POWER button once and ensure that the instrument panel (the speedo and so forth) is off. It is not necessary to press "P" (or Park) before turning off the car (since the shifter is electronic and will automatically engage Park when you shut off the car) but if you feel more comfortable doing so, then press "P" and then POWER.
    If the car beeps at you when you're outside, pay attention. Chances are, you left the car running in Park.
  10. Echoezra
    42
    Thank you SO much again!
    And yeah, that Insight test drive was back in October. I figured it was just from sitting. It still is, btw. A shame, wasting a hybrid like that...
  11. Tideland Prius
    16,160
    Considering Honda Canada didn't update their Insight page for an entire year (went from 2011 to 2013... so maybe there is no 2012 Insight??), I don't think they have much interest in it. Their new Accord Hybrid is one to watch but nobody knows if it's coming to Canada.
  12. Echoezra
    42
    Hey guys I just wanted to bump this up to see if I could get an idea of some average Canadian dealer maintenance service costs from any of you? Just trying to plan out a little budget, so any input would be great, rather than me just guessing, as I'm always unpleasantly surprised by the real world. Lol.
  13. Echoezra
    42
    Anything? Anyone? You don't have to be Canadian, just say where you're from, I imagine anywhere where its a smaller city with only one Toyota dealership would be comparable in pricing...
  14. Tideland Prius
    16,160
    $40-$50 for an oil change (first 3 services, then it alternates oil change & full service)
    closer to $200 for a full maintenance service and add another $100 for this new "brake service" that's done at 32,000km and every 32,000km thereafter.
    Service includes check of lights, horns, locks (and lubrication if necessary) and fluid top up. The full maintenance no longer includes tyre rotation.
  15. Echoezra
    42
    Thanks to you once again Tideland. :)
    I had done some more math, talked myself into it, and finally went up to the city today to test drive it, only to find it had sold on the weekend. Gah. There's not another used prius anywhere in the county. :(
  16. Tideland Prius
    16,160
  17. Echoezra
    42
    Yup. Annnd.. To top all this off, just because the universe hates me, lol, my car (my trade-in) spontaneously starts making this new noise... Im like "ruh-rohh.." Brought it to a nearby local mechanic who tells me yesterday that it sounds like transmission issues. Yayy.
  18. Tideland Prius
    16,160
    Uhh... bummer. :(.
