CanDecoder V1.8 - recompiled for Mac OSX
Discussion in 'Prius PHEV Plug-In Modifications' started by aminorjourney, Oct 12, 2008.
  1. aminorjourney
    aminorjourney Mum to two prius!
    335
    27
    Bristol, UK
    Hi everyone,
    This is just a quick note to let you all know that I downloaded the source code for the excellent CAN-Decoder by Gary Morris and converted it to be used as a mac app. It was originally written for windows and converts the raw data .bin file that is output from the serial port of CAN-View to a .csv file which can be viewed in Microsoft Excell (or for that matter, Apple's iWork suite)
    The application is still only a simple command line program, but can be run in the OS X terminal Applicaion.
    Once you've captured the .bin file then start the CAN-Decoder Terminal app and when prompted either enter the location of the file to be converted or do a drag + drop.
    I should point out here that all I've done is recompile the excellent source code from Gary's site. I have done nothing else. He should be credited with all the hard work!
    I've attached it here - let me know how you get on.
    Nikki.
    P.S. If the drag+drop doesn't work then make sure there isn't a space at the end of the filename - do a backspace to check!
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Cool! This is why I like open source! :D
    So have you started using the CAN-view to capture data? If so did you make the necessary changes to make the program compatible with the V4+ CAN-view data? I'm assuming that your using the V4+ since you have a 2007 Prius.
    Also is the file that you included in the zip the executable and the source or is it just the executable?
  3. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    I have an usused Mac Mini.
    Care anyone share an "idiot's guide" with pictures?
  4. fernelius
    fernelius Junior Member
    17
    Pennsylvania
    If you have a used Mac Mini sitting around and want to install it in your Prius, you might find the following link useful.
    MacPrius
    I imagine you could add the CanDecoder software also if you want to record data.
    Have been thinking about this for a while, but I, unfortunately, don't have a MacMini sitting around. :)
  5. linuxpenguin
    linuxpenguin Active Member
    352
    182
    Hey guys,
    This topic may be dead--but in the event that it isn't, I worked on a CANBUS display for the PHEV Prius awhile back called CANTOP (cantop . sourceforge . net **remove the spaces**)
    It runs JAVA and QT (server and client respectively) and uses a low-cost CANBUS to USB converter called CANdapter (candapter . com ** remove the spaces**) for it's vehicle integration.
    It's far from finished, but it's pretty customizable if you have at least a little programming experience. If anyone is interested in developing it more I can help them get started.
    Oh yes, and it's open source too.
    Andrew
  6. kenoarto
    398
    Chicago, IL
    I'm not a programmer, nor am I afraid of computers. If you could supply a basic guide. I'd love to give it a shot.
    thanks
