Cannot disconnect ChargePoint charge cable
Discussion in 'Prime Plug-in Charging' started by Jim Powell, Mar 7, 2019.
  1. Jim Powell
    Jim Powell Junior Member
    Boulder Creek, California
    I've been charging my 2017 Prius Prime Advanced at work for almost a year on ChargePoint chargers, with no problems at all. Today, I went out to unplug when my car finished charging, and I couldn't get the charge cable to disconnect from the car. I had my key with me, and I could clearly see the locking mechanism moving in and out when I pressed the charge cable lock button. I went in circles with ChargePoint, the local Toyota dealer who services my car and Toyota Roadside Assistance. I finally had to give up and have my wife come pick me up at work. I'm headed back to the dealer tomorrow, who said they would be more helpful when they had both mechanics and managers available. In the meantime, has anyone had this problem? I didn't see anything in this forum, other than one person who didn't have his/her key on their person. I'll post an update when I get the problem fixed... I can't believe how many people suggested that I have the car towed to the dealership :)
  2. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    Is it the same ChargePoint charger cable you have been using in the past? Have you always used the connector locking system by pushing the small button inside of the charge port? (red arrow in the diagram) Did the SKS work with your key for the other doors (2 front doors and 1 hatch? I guess it is possible that the antenna for the charge port is specifically damaged. Maybe battery in the fob is weak???
    IDK. I hope you can solve this mystery quickly, but whatever you find out, please let us know the solution.
  3. Salamander_King
    11,019
    8,954
    New England
    Since the lock mechanism is responding to you manually pressing the switch, this may not help, but have you tried this emergency procedure?
  4. Jim Powell
    Thanks - yes, I did try the emergency procedure as well. I was glad to learn about that procedure, even though it didn't help this time. This morning a local Toyota mechanic came out, and after verifying that there were no other locks in the system, he muscled out the charge connector. One of the charger pins appeared to have fused into the socket, and remained behind in my Prius. My Toyota dealer now has the car and they are investigating what went wrong. When they let me know what happened, I will update this post for future reference.
  5. Salamander_King
    11,019
    8,954
    New England
    Wow!, You must be glad it did not cause a fire or something. I wonder if it was the car or Charge Point charger that caused this. Obviously, the charger cord must be out of use as well. Is Charge Point doing any investigation?
  6. CMPTosh
    CMPTosh Junior Member
    17
    Interesting. I had an extension cord fuse to the receptacle on my leaf blower a few years ago. Sounds like the same type of situation.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    WOW!!
    From that second picture showing the Charge Port part stuck in your charging port, it looks like the Charge Port pin was severely corroded.
  8. Jim Powell
    Finally received word from ChargePoint - they have no idea what caused the problem, and didn't see anything wrong with their system or the charging connector. Toyota (a long time ago now) also found nothing in the car that might have caused the problem. So, unfortunately, I have no idea what caused the problem in the first place.
  9. Salamander_King
    11,019
    8,954
    New England
    Thanks for the update. Was repair covered by warranty or did you have to pay out of your pocket?
  10. Jim Powell
    Out of pocket, as neither Toyota or ChargePoint believe their side to be at fault. So I guess I must have plugged it in wrong o_O Fortunately, our insurance will cover the repair cost.
    Salamander_King and bisco like this.
  11. bisco
    52,011
    bummer. sounds like you are being blamed for either charge point or toyotas problem
  12. Salamander_King
    11,019
    8,954
    New England
    Was that your comprehensive that paid for the repair on the car? Did you (or your insurance) have to pay to repair the ChargePoint EVSE too?
  13. DavidA
    2,345
    1,821
    Chicago western burbs
    Corrosion in the ChargePoint J1772 increasing the diameter of the terminal? That might explain it getting stuck in there.
  14. Jim Powell
    Yes, since no one knows what caused it, we have a blame vacuum. Which has sucked me up into it. Oh well, there are worse problems in life...
    That makes a lot of sense. I am going to pay attention to the charge contacts when I plug in, and see if I ever notice anything unusual. Thanks!
    My comprehensive covered the cost of the Prius repair. I'm not sure if ChargePoint or my company paid for the repairs to the charger - that had never occurred to me! I'm glad it didn't come up.
    #14 Jim Powell, May 19, 2019
  15. Elyssa
    Elyssa New Member
    Massachusetts
    Thanks for the response. I'm unable to find the emergency release lever. I can't tell from the illustration exactly where it is. I've tried pushing in a few places, but I'm not certain that I'm pushing in the right spot since I can't see anything that looks or feels like the lever in the illustration. Attached is a photo of the area. Can you add more guidance?
  16. Elyssa
    Elyssa New Member
    Massachusetts
    I found the lever, but pushing it in didn't work. I called the dealership and I'm having the car towed there.
  17. 6pk4sp
    6pk4sp New Member
    Los Banos, California
    2020 Prius Prime
    As a professional electrician who has worked with high voltage systems, and my forte as a troubleshooter I wanted to add my two cents worth. Sometimes it is hard to determine the EXACT root cause of the problem, but the symptoms can point us in the right direction. The charging port and charging cable connector are commonly referred to in my trade as a "Pin and Sleeve" style. They are often used in higher voltage and higher amperage situations where safety is important to avoid hazards. Looking at Mr. Powell's pictures of his damaged charging port and the corresponding cable connector, it appears that his affected "Pin" in his port is discolored, it is a different shade than his other unaffected pin. This leads me to suspect that exact pin and sleeve incurred excess heat, and this caused insulation (plastic or Bakelite or etc.) to expand/deform making it hard to be removed. I have seen this before with 480 volt welding pin and sleeve connections. The insulation around the damaged pin and sleeve had to broken apart to allow the parts to come away from each other. Usually a poor or bad connection caused excess heat which began to deform or corrode the affected parts.
    "IF" you could cut open each side of the port and cable connector to see which exact section showed the most heat damage, you would have found where the problem started. It is just like tracing the beginnings of a fire, the worst burned part is where it started. "BUT" the how or why it started in that spot can have many factors. Maybe a previous loose connection that partially damaged things could have contributed to it all? That is, maybe a damaged connector left by another user with a bad port, and we see the final damage the next time it was used, which was on Mr. Powell's port? Maybe the cable connector was not all the way in? Maybe the wire-to-pin connection inside the Prius port was not made solidly, and it slowly was going bad with each use?
    In my trade unless someone is demanding an exact cause, which can be impossible to tell without hours of research, I cut off both connectors and strip insulation back to expose undamaged copper metal wire and put on new "Pin and Sleeve" connectors on both sides.
    The cost of the research, along with the cost of systems being out of service and workers standing idle waiting for repairs, almost always means we cut to the chase and get things repaired ASAP and move on.
    Zythryn, vvillovv and Deb Rothschild like this.
  18. Mr.Vanvandenburg
    1,356
    574
    2020 Prius Prime
    Noticed this problem was in 2019.
    #18 Mr.Vanvandenburg, Aug 26, 2023
  19. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    And another similar issue reported in 2022 Still a good description of how to find the cause of why things like the EVSE getting stuck in the charge port can help others that read it troubleshoot similar EVSE, Primes charge port issues.
    #19 vvillovv, Aug 30, 2023
