Cannot get prius into neutral. All gears flashing
Discussion in 'Gen 2 Prius Technical Discussion' started by andy song, Dec 24, 2025 at 4:29 PM.
  1. andy song
    andy song Junior Member
    Hi all
    Bought a 2008 prius with 263k
    Previous owner said it drove fine 4 years ago but has been sitting
    We put a new hybrid battery pack we had from another in
    We put a new 12v in
    The car just flashes the gear selectors
    Won't go into neutral
    The relays of the hybrid battery do not click
    I checked all the micro fuses in the engine fuse box and they are all good (including the AM2 fuse)
    Anyone have the same thing?
    52,001
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,050
    1,976
    NJ-USA
    x2 to bisco.
    Could be lots of things. Getting codes from all ecu's with a capable scantool would help narrow down the possibilities.
    That said, wouldn't be surprised if there was a corroded blue wire at a connector at the "rear" of the underhood fuse box. Located under the black plastic cover. It's not an uncommon fault that takes the "TCM" (transmission park mechanism) offline.
  4. Tombukt2
    Tombukt2 Senior Member
    13,047
    2,338
    Durham NC
    What is your vote meter say that the new hybrid battery pack from other has on it rt now ? Those relays have to click or you're essentially locked out for some reason . I would think the car would tell you. usually when you're locked out of ready mode well. Things ain't ready to be readied apparently . 4 or 5 books is the size of this cars service manual and lotsa reading . Of all the things that can lock you out. Electronically that is
