Cannot go to setting
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nav4evr, Aug 8, 2011.
  1. nav4evr
    nav4evr New Member
    Sri Lanka
    So I wanted to change the language on my Prius! But then I cant go to the setting through the steering wheel by holding the 'disp' button!
    Any help is appreciated!
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Are you in Park when trying to make the setting changes? Toyota will not let you make changes while the car is moving.
  3. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    I don't know if it's the same on the US models, but on the UK version you don't hold the Disp button, you just press it repeatedly, cycling through the different displays until you get to the settings one.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Yes, same here. With the car in Park push the Disp button until you get to settings, then push it and hold until the settings menu comes up. Then do the same thing, push Disp until you get to Languages, then push and hold. Then push Disp again until you get to the language you want and push and hold. Same thing to exit the settings menu.
