Cannot recognize the Battery cell to be changed
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Bobtale, Apr 19, 2022.
  1. Bobtale
    Bobtale Junior Member
    TUCSON, AZ
    I have a 2007 Prius. I have pretty much done everything on this car. recently I educated myself through the chat here and some youtube instruction to commit to changing a faulty cell in the battery pack. When I did it succesfully, Ii was so happy. Recently, again I am getting the triangle of death, and I am certain it is another cell in the battery pack. However, when I run the Dr.Prius app, I am confused over which cell is faulty. I need some help to read of and point to the right cell. Can someone help me with that? I am attaching the Dr. Prius screenshot.
  2. BiomedO1
    BiomedO1 Senior Member
    4,186
    2,187
    SacTown, Ca
    sorry to hear about your issues; but on a 15 year pack that bakes in the AZ sun - replacing 1 in 28 batteries is like playing wack-a-mole.
    The way the batteries are chained together, the Dr. Prius app is giving you a location on where it thinks the dead cell is. You still need to do an individual cell voltage and load test. A simple voltage test isn't going to cut it, since your can have voltage, but the battery's load output could be very low or zero. As most people know, a battery's load output of zero is useless. It can't perform any work; that's why you need to separate it out of the network to test it. Trying to test for a bad cell within the network, the bad cell can rely on adjacent cells to pass the test.
    According to your jpg; you've got a minimum of 6 questionable cells, 3 pairs that need testing. You should test all of them, when you have the pack apart - otherwise you'll be doing this again in 6 months or less. Look up: load testing a battery and why. YouTube and google are a great resource and learning tool; but the devil is in the details. While most YouTubers don't profess to be experts; there is good information mixed along with very bad information that can be outright wrong and dangerous. Just like here.....
    Good Luck...
  3. Albert Barbuto
    Albert Barbuto Active Member
    113
    104
    Northeast USA
    Monitoring the pack in real time is the key to locating weak modules. The two pics below show a full throttle acceleration from a dead stop, (146 amp draw) and a milder 31 amp load, while backing up an incline. In both cases module #27 was weak. Repeated cycling of #27 right in the car did not bring it back to life, so the pack was removed from the car, and #27 was replaced.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    So you mentioned getting the RTOD. If it is the HV battery, you likely have a P0A80 and perhaps an additional code P30xx to tell you which block. If only a P0A80, then the car knows there's an issue, but hasn't determined exactly which block yet, but it will.
    The P0A80 will allow you to continue driving normally. Once the P30xx triggers, the car will essentially go to limp mode.
  5. PriusCamper
    PriusCamper Senior Member
    13,088
    5,308
    Pacific Northwest, USA
    You're in the early stage where "voltage diff." is still relatively normal most of the time so keep grabbing screenshots of Dr. Prius app as you clear the triangle during the still rare abnormal time. Then when you have time to pull the pack load test everything and then review all your screenshots to decide on which modules you wanna replace.
  6. Bobtale
    TUCSON, AZ
    The great information is given and I really appreciate it all. That brings me to another question and I will definitely search the forum: what is the usage of "Grid Charger" and would it save me a hassle to use it instead of changing the cell(s)?
  7. PriusCamper
    13,088
    5,308
    In the early stages of deterioration a charge and balance and a few rounds of reconditioning can make a huge difference of bringing a pack back to normal, but if you're constantly pulling more than 1.0 volt in voltage difference that's a bad cell that's not gonna get better and that module needs to be replaced.
  8. Bobtale
    TUCSON, AZ
    Thanks for all the helpful hints and information. I went ahead and replaced 28 modules with Refurbished Balanced cells. To my astonishment, I am still getting the Triangle of death, along with the same drop in power. I have to continuously reset using OBDII app and still in some cases that do not help either, the only remedy is to restart the engine. This indicates that there is something else that may cause this. I had replaced the water pump about a year ago, and when I check the refill container while the engine running, the water pump seems to be functioning. What else could cause this issue? Alternator?
  9. PriusCamper
    13,088
    5,308
    The loss in power is usually the engine computers sensing a problem then throwing a red triangle and then going into limp mode where you only have engine power not electrical power.
    Did you inspect the voltage sensor plug where it plugs into hybrid battery ECU? That connection tends to corrode and fry that ECU. Also it's possible person you bought modules from sold you some bad ones.
    Bobtale likes this.
