Canoe and Kayak Tie Down Anchor Locations? - Gen 4
Discussion in 'Gen 4 Prius Main Forum' started by ken2116, Jun 22, 2019.
  1. ken2116
    ken2116 Junior Member
    40
    16
    Northern CA
    2019 Prius
    We wish to carry a 16-17ft canoe on our Gen 4 and desire suggestions for where to anchor front and rear tie downs at the right and left. The two towing eye anchors at the front and single eye anchor at the right rear appear to be candidates.
    1. Can anyone suggest a specific, reasonably priced alternative anchor eye or bolt to fit the car (Toyota's price for a towing eye is beyond belief). Is the anchor's thread specification known (I can measure the pitch, but which standard is the thread)?
    2. Are there suggestions for a rear left anchor point? Both the lower control arm and the body anchor stud (or bolt) to the rear subframe appear serviceable but require sliding under the car and we'd prefer a place that can be reached without having to lie on one's back. Are there good places (existing bolts or holes in sound metal) under the bumper and underbody plastic covers (I'm willing to cut access holes)?
    When carried on other cars our boat occasionally gets hammered by cross gusts stronger than the front and rear stays (and straps at the carrier bars) can control, twisting the boat sideways and vastly increasing the wind load - we've had success tying another stay (rope, or nylon webbing for more tire clearance) to the front coil spring on the windward side, padding it with foam pipe insulation and, when we care about the car's finish, applying clear body tape to that area of the fender.
  2. roger frick
    roger frick New Member
    MN
    2018 Prius
    When we bought our kayaks, the kayak dealership also sold us four 6" long pvc tubes with looped straps threaded through them. Once they're in the right place under the hood, the hood will shut cleanly. In the back of the car, let the straps hang out from inside the trunk. Anyway, with the hood and the trunk shut, you'll have exterior straps through which you can tie your paddle craft down. IMG_1309.jpg IMG_1310.jpg IMG_1312.jpg
    kc5dlo likes this.
  3. ken2116
    40
    16
    Northern CA
    2019 Prius
    Thanks. I prefer to tie off to the frame or something solid that is connected to it, especially at the front, for several reasons: Driving across the planes at interstate speeds while passing semi's in heavy cross winds, gusts can really "rock the boat" in ways that I can imagine damaging thin sheet metal. I've encountered similar gusts off the ocean while approaching the GG Bridge from Marin on windy afternoons, and have had anchor straps abrade paint on other cars.
    One solution for the side loads from cross gusts is anchoring to the front coil springs using a loops of webbing, padded with soft fabric where they wrap around the fender edges - that hasn't hurt my other cars (Merc. Villager, Volvo, Outback) but I haven't tried it with the Prius.
    Mambo Dave likes this.
  4. Zlakin
    Zlakin New Member
    I use this anchor SeaChoice 41610 on my 14ft Jon boat. First off it’s the weight. This is so light I couldn’t believe it. The second was the hold. Once I figure out how it works you won’t move. I had this in 12-16mph winds, and my boat never moved from its spot.
