Can't be !! Coolant valve already
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by alanwagen, Apr 10, 2011.
  1. alanwagen
    alanwagen Member
    121
    79
    FORT WORTH
    2018 Prius
    I am totally POed about my wifes 09 with 40k already needing a coolant valve at the tune of $332.61 Where the heck is Toyota's legendary reliability? We had two Buicks before that did need any service. Her check engine light came on, so we took it in and was told about a "COOLANT FLOW CONTROL VALVE" being stuck. Of course not under any warranty such as powertrain or emissions. I wonder if this is common and if there is a secret warranty? Should I contact the manufacturer? Please advise.:suspicious:
  2. richard schumacher
    7,663
    1,040
    United States
    Ask the dealer which DTCs were reported. Did anyone ever add the wrong coolant? If not, it's worth a call to Toyota to see whether they will chip in.
    Otherwise, yeah, stuff does happen.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Please list all services performed on your car other than oil+filter changes and tire rotations -- i.e. there should not have been anything else done other than those on a car this young. Is there any reason to think that someone serviced the cooling system and did not bleed/refill it properly? Or for some reason they disconnected the hoses and reconnected them wrong?
    EDIT: warranty only covers the valve to 3/36. But failure on an '09 is unusual, due to the introduction of a redesigned component.
  4. alanwagen
    alanwagen Member
    121
    79
    FORT WORTH
    2018 Prius
    All we had done was oil changes and air filters. Nothing else. Maybe it is a anomaly but I did notice other posts concerning the Coolant valve. It is almost embarrassing that this happened to such a newish car. It just reinforces the naysayers against the Prius.
  5. bisco
    49,698
    no warranty?
  6. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Why doesn't the powertrain warranty cover this? The coolant is a necessary part of the engine. I'd really make a stink about it with Toyota's regional rep. Plus the car is only 4k mi. over the basic warranty.
  7. alanwagen
    alanwagen Member
    121
    79
    FORT WORTH
    2018 Prius
    I sent an e-mail to Toyota customer service, I will update with the results.
  8. richard schumacher
    7,663
    1,040
    United States
    Also get it diagnosed a a different dealer. They do make mistakes.
  9. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    The TSB that applies to 04-07 quotes 3 years/36,000 miles as the warranty coverage. It's really odd that they can get away with basic warranty coverage since it is an emissions component! Failure this early in an 09 is unusual though.
    By the way, $333 is a reasonable price for this repair.
  10. alanwagen
    alanwagen Member
    121
    79
    FORT WORTH
    2018 Prius
    I have to take it back. The coolant is low, broken upper push clip, missing lower panel clip and missing screw on lower panel near front bumper.
    Some snotty nose kid must of done this. What should I ask for my trouble?
    Now I am justified to be POed.
  11. jdenenberg
    jdenenberg EE Professor
    3,859
    1,858
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Low ICE coolant can cause the valve to stick as the coolant acts as a lubricant. It is easy to have low coolant after a coolant refresh as one has to take care to remove any air in the system. The same happened to me and I had the dealer pop for a flatbed tow back to correct the problem. They are now unlikely to make the same mistake again.
    JeffD
  12. alanwagen
    alanwagen Member
    121
    79
    FORT WORTH
    2018 Prius
    Good news, after I contacted Toyota Customer Service via the net, they waived the charges and will refund our money. I had to fax the work orders and they granted a one time good will gesture. This goes to show that it never hurts to ask.
    best regards, :)
