Can't figure out the problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ugly duckling, May 11, 2015.
  1. Ugly duckling
    Ugly duckling New Member
    Sacramento
    image.jpg Change all my injectors still it has misfire.
  2. JC91006
    16,496
    8,406
    spark plugs, coils?
  3. Ugly duckling
    Sacramento
    Yeah I change that to. Do you think it's the O2 sensor
  4. JC91006
    16,496
    8,406
    did you get the original denso plugs and coils? I've read lots of the aftermarket stuff doesn't work.
    You can try moving the #2 cylinder coil (seems to be good) to the other cylinders and see if changes things.
    History on the car?
    #4 JC91006, May 11, 2015
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    on the other hand you might want to figure out why you have 2 evap codes. makes me wonder if you're running lean...
  6. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    P0300 I have that on my Prius. It's a brand new ride. Dealer say it was normal. Does your engine shake a lot with those misfired?
  7. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
    that's a nice print out of the codes
  8. bisco
    49,734
    how many miles on her?
  9. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    Bentley states, P0455 [Evaporative Emission Control System Leak Detected (gross leak)] is same as DTC P0442 (in terms of diagnosis aspects to eliminate).
    P0442 - Evaporative Emission control System Leak Detected (small leak).
    P0441 - Evaporative Emission Control System Incorrect Purge Flow.
    Both (P0441, P0442) have the same diagnostic trouble areas to resolve:
    • fuel tank cap correctly installed
    • fuel tank cap is cracked or damaged
    • vaccum hose cracks are blocked, damaged, or disconnected in Figure 1 of the circuit description; reference the circuit diagram for the fuel system
    • open or short in vapor pressure sensor circuit
    • vapor pressure sensor
    • open or short in VSV circuit for EVAP
    • VSV for EVAP
    • open or short in VSV circuit for CCV
    • VSV for CCV
    • open or short in VSV circuit for pressure switching valve
    • VSV for pressure switching valve
    • fuel tank is cracked or damaged
    • charcoal canister is cracked or damaged
    • fuel tank over fill check valve is cracked or damaged
    • ECM
    Did you recently top off? There are quite a few valves in the fuel evap recovery; possibly one or more is stuck in wrong position. One top off is unlikely to cause this, but multiple top offs from previous owners could.
    Good luck.
  10. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Let me get this straight. Your Prius is throwing a code, P0300, which is evidently random multiple cylinder misfires, and they are saying it's "normal"?
    If your engine is misfiring and shaking a lot and throwing that code? I would venture to say that's not "normal" and investigation is warranted.
    valde3 likes this.
  11. ChapmanF
    15,924
    I have to agree with 69shovlhed ... it's a little bit unfocused to be throwing around other usual-suspect misfire causes like plugs, coils, O2 sensor, etc., all while a large evap leak is shown on the screenshot in the very first post....
    -Chap
  12. Ugly duckling
    Sacramento
    yes my car still shakes a lot
  13. Ugly duckling
    Sacramento
    My car is at 80000 miles
  14. Ugly duckling
    Sacramento
    Its making this noise
  15. bisco
    49,734
    sounds like a trip to the dealer for expert analysis.
  16. ChapmanF
    15,924
    Anything, Bre'r Fox, anything, just please, never look into those evap codes.
    -Chap
    strawbrad and dolj like this.
  17. apt5020
    881
    1,294
    Prius City, CA
    Shake meant your coil is bad. Replace 1,3, and 4 from your error code. Since you have around 80K miles. Just replace the spark plug when your doing that. Bad coil = lost of power when driving.
  18. ChapmanF
    15,924
    Right, that has to be it. Whatever you do, don't even think of looking for the large vacuum leak the computer is telling you about.
    -Chap
  19. 69shovlhed
    2,170
    748
    Delaware
    if your engine is missing (shaking), and throwing a P0300 code, and a DEALER told you it was normal, you need to call Toyota and complain about incompetent dealer, and definitely never go there again. it is never normal for an engine to misfire. and it ain't good for the motor to misfire all the time. if it hiccupped once and set a P0300, and the dealer cleared it and it hasn't done it again, that would be one thing. but if the CEL is on, there is a problem. any competent, honest shop would try to figure it out, not lie to you.
  20. 69shovlhed
    2,170
    748
    Delaware
    not. it could be a bad coil, or bad plugs, or an injector, or a broken valve spring or ...
    if it was only one cylinder I would swap the coil with another cylinder and see if the miss moves, but I doubt 3 coils gonna go bad all at once. its probably got a vacuum leak and its running lean. many times with a vac leak, you can hear it hissing while the engine idles. look for damaged or unhooked vacuum lines with a strong flash light.
