Can't find an oil leak.
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Nov 8, 2024.
  1. Prius92
    Prius92 Active Member
    484
    109
    Iowa
    It looks like the bottom of the timing chain cover, but then I saw a bit on the area and bolt above it.
    Don't see any drip down from the crank seal.
    Nor from the sides of the timing cover.
  2. PriusCamper
    PriusCamper Senior Member
    11,982
    4,871
    Pacific Northwest, USA
    Best way to find it is to keep cleaning engine areas that are hard to reach... If you get into a regular routine of doing that you'll eventually figure it out because the cleaned areas will get oily again real quick. In the meantime tighten the timing chain cover bolts as best you can and see it that helps.
  3. Prius92
    484
    109
    Iowa
    Have you ever used leak detection dye?
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,939
    1,900
    NJ-USA
    You've got what looks like a very minor oil seep on a 15-20 year old car. If that's all there is it might not be worth pursuing this.
    The only things in that area are the crank seal, the crank postion sensor, and the timing cover itself.
    #4 mr_guy_mann, Nov 10, 2024
