Can't find tire pressure RESET switch
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Randall Rash, Aug 2, 2009.
  1. Randall Rash
    Randall Rash Member
    149
    25
    Rockwall, TX
    I don't have a tire pressure RESET switch in the position under the steering wheel as depicted in the manual. Am I just blind?
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Re: Can't finf tire pressure RESET switch
    I had a hard time finding it myself the first time. Get a flashlight and look under the dash by the steering column.
  3. Randall Rash
    Randall Rash Member
    149
    25
    Rockwall, TX
    Ahhh. Got it. That is waay down there. Thank you.
  4. cpatch
    cpatch New Member
    383
    81
    Carlsbad, CA
    I had the same problem...the manual makes it look like it's up higher. At least I know where the OBDII connector is now!
  5. Glider
    Glider New Member
    135
    30
    Memphis
    thanks for this thread. i am bumping my psi up by 10 or so and have been wanting to do this.
  6. topkick
    topkick Member
    166
    Oklahoma City
    I could have used this thread yesterday.:) I looked and then got the book out and looked more, still could not find it. I started to come here and also ask the question, but decided to look one more time and found it.
    On my 2007 it was easy to find, but anyway now I know.:rockon:
    Jim
  7. Vaughn
    Vaughn Junior Member
    37
    Lubbock TX
    I think the reason for it being so low is the driver's knee airbag.
  8. jbedi
    jbedi New Member
    26
    sf bay area
    Am I correct to assume that after I increase my tires' psi, I should press the reset switch? Or , do I press the switch only if tire pressure light comes on after I increase psi to 42/40 level? This is the first car I have owned that came with a pressure reset switch.
  9. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    The TPM is set for a 8 psi diff. from factory plate settings.
    If you run your tires at a higher pressure then those on door plate then it is a good idea to reset it so it knows there is a new pressure and it will still alarm on the 8 psi diff.
    It's more then just pushing the reset button. There is a post on the forum someplace on how to do it. It might even be in the manual but i haven't looked and it's out in the car right now. Might try afew serches on forum to see if you can find it...it has to do with the TPM light on the dash blinking.
    Hope this helps
    I hope i got all this right.
    If not someone will jump in.
  10. stream
    2,977
    452
    Long Island, NY
    Yes. Press and hold while the symbol on the dash blinks and goes out.
  11. jbedi
    jbedi New Member
    26
    sf bay area
    Thanks for the info.
  12. jbedi
    jbedi New Member
    26
    sf bay area
  13. balmeral
    balmeral Junior Member
    Iowa
    So I have looked for so long and I still can't find this button. ALL I see under the steering wheel is a button that says key. My email is [email protected] if someone wants to take a picture, or else just give me some landmarks like the obdII etc. Thanks.
  14. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    It is located right next to the "key" button. Did your 2005 Prius come with TPMS?
    Tom
  15. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    TPMS was first installed in 2006. The 2004/2005 do not have it.
  16. balmeral
    Iowa
    Alright thanks for clearing that up. I bought my car from a Ford dealership a few weeks ago and I asked about the ((!)) symbol on the dash. He said it was from the tire pressure monitoring system so I just took his word for it. I am guessing it is probably something relating to the brakes?
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    8 psi under desired pressure is pretty gross. It would make sense to add an extra 4 psi before setting it, then bleed off the 4 psi to your desired pressure so it goes off at 4 psi below your desired pressure. Or maybe closer than 4 psi.
  18. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    Everytime someone starts a new thread asking this question I post this picture.
    archae86, SHH, Hasan and 3 others like this.
  19. balmeral
    Iowa
  20. Mendel Leisk
    41,522
    Haven't got it handy, but the Owners Manual says something to the effect of letting the car sit in Ready mode (on) for "a few minutes", after doing the reset. Anyone know anything more definitive on that time interval?
