Can't fix low climate score
Discussion in 'Gen 4 Prius Main Forum' started by BenYL, May 10, 2018.
  1. BenYL
    BenYL New Member
    Rockville, MD
    I
    The car is giving my 'D's for the end-of-trip driving scores because the climate control score is always 1 bar. I have the AC off and I'm on a standard vent setting. I have the temperature set all the way down but of course this is fine efficiency-wise because its just the fan blowing. The manual says when the AC is off the climate score is disabled. The only way to get more bars is to turn the temperature (heat) up and cook myself. How do I fix this?!
  2. Tideland Prius
    16,125
    Either don't worry about the climate score, or raise the temperature and run it in AUTO mode.
    In AUTO mode, the climate control has much finer control over the fan speed and electricity consumption compared to manual mode (or whatever you're using).
    I suspect your low temperature setting is also triggering the low climate score but I don't know for sure.
    RCO likes this.
  3. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    I would agree the low temperature setting kills your score. The further the set temperature is away from the actual temperature, the harder the climate control (anything that's still left on automatic mode) will try to get to that temperature, at the expense of being economical. This could be running the fan harder, running the aircon harder, taking heat away from the engine (which means it may have to start up more often to maintain an optimal temperature), and so on.
    I think one thing that isn't appreciated often enough, is that modern climate control can be very clever. It knows that when the cabin is super hot the best way to cool it is to make as much airflow as possible towards the roof of the car (where the hot air has risen to). It knows that as it cools down a bit, it's better to aim the vents at your face/chest and slow the fan down to a comfortable level and take advantage of your perspiration. It knows the humidity in the car and the temperature to so knows how effective your own body's cooling will be and hence when to do this. It knows that as the cabin temperature gets very close to the target temperature it can really back off on the fan. It knows when the aircon is on it's better to use recirculate so it only has to cool the air in the cabin and not the outside air continuously, assuming it's vented the super-hot air already of course. It knows when it's humid and cold that it'll want to give more air to the glass to prevent steaming up, etc. It knows how much electricity the aircon uses, and it knows the state of the battery and engine. If the battery is full and the engine needs to run for whatever reason then why not use that spare electricity to run the aircon? It'll do all that.
    If you set the target temperature to something different than what you actually want it to be, then it screws up all that smart stuff. You're not only making yourself suffer more, but you're preventing the car being as economical as it could.
    There are other effects too, although perhaps more applicable to colder climates... The air into the cabin also passes through the vent on corner of the rear seats and into the traction battery compartment. Essentially, cabin temperature and air flow have an impact on the battery temperature. The optimal temperature of the batteries will depend on whether you're using NiMH or LiIon, but in general they can accept the most charge and deliver the most output when warmer. In fact, it's quite difficult to charge these types of batteries as they fall below 10C/50F, and their maximum output takes a huge hit.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    I wouldn't worry about the score if that's the case. I can't say that I've taken much notice of it after my first month or so Prius driving. I use A/C most of the time except winter (like I turned it off part of today) - the more severe the heat, the worse the score - but it doesn't make a huge difference.
    RCO and krmcg like this.
  5. BenYL
    BenYL New Member
    Rockville, MD
    I
    So that's just the way it is? Kind of annoying, I guess because I just got the car. When the AC is off it should not even give a climate score or maybe take a bar for high fan speeds since the fan doesn't consume much energy. This is basically a bug right? I'll try the auto mode.
    On a different note, is there a way to disable the end-of-drive scores? My wife says it is getting in the way of her and the car "bonding" especially since it always gives her failing scores.
    RCO likes this.
  6. Mendel Leisk
    38,644
    I think you're doing fine, just ignore that nonsense.
  7. alanclarkeau
    7,044
    7,584
    Don't think you can disable it. Just give yourself a PERFECT SCORE for climate when you don't use A/C.
  8. Harters
    Harters Active Member
    335
    424
    UK
    Excel
    I have mine set to Auto 21oC (with A/C) using the Eco setting on the CC (not the drive mode) and I always get highest score.
    In our climate I find 21oC to be perfect for me, warm enough when its cold and cool enough when its hot.
    RCO and kithmo like this.
  9. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    In college I took a class entitled "The Poetry of Contemporary Music." For my end-of-course project I wrote a song, the last line of which was, "A good D's all I need to be in that graduation line; so here I come!" So about your "low" score? I say celebrate! Enjoy the ride.
    Sent using Hello Moto
  10. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    I have mine set exactly the same here and the nearer to ambient temperature you set it the better the score.
    FWIW, Gen 4, if you turn the climate control off altogether then you get full marks as well.
    RCO, alanclarkeau and Harters like this.
  11. Harters
    335
    424
    UK
    Excel
    Isn't that cheating? :LOL:
  12. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    RCO, Harters, alanclarkeau and 2 others like this.
  13. Since2002
    Since2002 Senior Lurker
    936
    1,097
    Duluth, GA
    kithmo and alanclarkeau like this.
  14. RoadNoise
    RoadNoise Active Member
    136
    187
    Huntsville, AL
    Two Eco
    There is a setting to disable the climate score. Been so long can't remember how but it's there somewhere. Don't like my comfort level requirements being graded.
  15. BenYL
    BenYL New Member
    Rockville, MD
    I
    Thanks for the moral support guys, I've succeeded in ignoring the end-of-trip score. Otherwise this car is incredible, a huge step up from my 2008 Prius. I actually got 92.2 mpg driving 25 miles to the airport. Yes it was kind of downhill, following the river, but I'm still in shock. The car has such low rolling resistance it's like riding a luge sled.
  16. RCO
    RCO Senior Member
    3,709
    5,183
    Cornwall
    Hmm, I like 20.5°C but wife prefers sub-15°C. We use those settings at the risk of thunderstorms inside the car!!!
    Analytically, I'd say that was. "On the sunny side of the wheel." :whistle:
    Grab your coat and get your hat
    Leave your worries on the doorstep
    Just direct your feet
    To the sunny side of the street. ©
    #16 RCO, May 27, 2018
    Harters, alanclarkeau and Since2002 like this.
