Can't get fluild into new wheel Cylinders help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by poppy, Jun 30, 2010.
  1. poppy
    poppy New Member
    DC
    I replaced the wheel cylinders in my 07' bled the RT rear first then left rear ..had no response from the cylinders. I reversed the order and still no fluid to the cylnders....I kep foot to floor opened the bleeder closed once I saw fluid and then closed the bleeder. after two hours of this I pumped while the bleeder was closed befor I depressed the brake and then opened to see fluid flow....stil no pressure to the cylinders...My light sre on the the dash no ABS all showing lit up. I gave up for the night the car has brakes in front and not rear. Can't figure this out.. Dealer wants 1k to check, I'll burn the car before I pay 1k for bleeding te lines. the car has rt rear cylinder leak the was only problem previous not lights or warnings indicating at that point...HELP any Ideas
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
  3. poppy
    poppy New Member
    DC
    Design flaw? What if I go with a pheonix fluid pump and reverse fill the lines?
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    You need the Toyota equipment to bleed the brake lines on a Prius.
  5. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Unfortunately you are going to have to have your car towed to the dealer, if all the mechanical replacements are done then the costs of using the dealers OBII Master Tech, handheld device is somewhere between $90-125, this device cost the dealership $6000. Only with this gadget can one bleed the brakes! Read Hobbits comments on his attempt to bleed the brakes.
    :cheer2:
  6. northwichita
    481
    102
    29
    Wichita KS
    Hobbit gave some good advice on this thread
    http://priuschat.com/forums/gen-ii-...ar-drum-brake-cynlinder-piston-poped-out.html
    basically he said
    If you are very sure you didn't get air back up the rear line far
    enough to land in the actuator, and didn't wind up draining out
    enough fluid to empty the reservoir, there's a good chance.....
    then describes how to bleed the rear brakes -without a scan tool- car is 'powered up';
    let us know how this goes.
    Good luck.
  7. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    In the older thread I have posted the shop manual section on how to bleed the brakes
    With all the solenoids involved, it is quite tricky - though not impossible - for a patient DIY.
    Read Hobbit's tutorial, it's very good
    For a dealer to have the balls to ask a gee just to look at the brakes, is the reason why Toyota dealerships have such a poor reputation overall
  8. jayman
    13,439
    640
    Winnipeg Manitoba
