Can't get into drivers door
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by fissshhh, Aug 25, 2018.
  1. fissshhh
    fissshhh Junior Member
    Staffordshire UK
    Active
    Hi! I have a 2009 Prius, and can't open the drivers side door either from inside or outside. All the other doors are fine.
    I can hear the actuator clunking inside the door.
    When I operate the handles (inside or outside) they don't feel as though they have any mechanical connection to anything.
    I suspect I'm looking at an actuator problem, but how on earth do I get inside the door without being able to open it? Hellllp!!!
    Cheers folks!
    49,387
    is it possible to remove the door interior with it closed?
  3. JC91006
    16,477
    8,394
    Here in the USA, you can find the interior door pieces fairly easily. I would guess you have to cut into it and find replacement piece
