Can't Jump Start 2011 Prius with Lithium Jump Starter
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by uncertain235, Feb 15, 2021.
  1. uncertain235
    uncertain235 New Member
    Philadephia
    I recently had the experience of going to start my 2011 Prius and finding that it had absolutely no electrical power showing up on the dash board. Could not open any door electronically. Could not open the hatch. Had to open the driver door with the mechanical key.
    I called the local Toyota dealership. They sent someone with a lead-acid battery jump starter. After a few tries we were able to get it to start. They then drove it back to the dealership where they eventually concluded that the 12V auxiliary battery was toast, even though it was less than 1 year old. They replaced it under warranty.
    But I decided after that experience that I wanted to be a little more in control of the situation the next time so I bought a TackLife T8 jump starter at Amazon. This is one of those newer, Lithium battery powered jump starters that's small enough to carry around in your car all the time and can even be recharged from the cigarette lighter.
    Problem is, I can't get it to work with the 2011 Prius. What I tried as a test was this..
    - Disconnect the 12V cable from the auxiliary batter in the rear. This was to simulate the totally dead battery condition that I had encountered previously.
    - Connect TackLife positive to the jump lug in the fuse box in the engine compartment.
    - Connect the TackLife negative to the engine block. I had to use an old fashion jumper cable to reach the engine block. The TackLife cable alone was way too short. And nothing I tried that could be reached with the short negative cable would close the circuit. Nonetheless, connecting to the engine block with a helper cable did close the circuit.
    - Press the Boost button on the TackLife. You need to do this because the TackLife looks for some level of battery voltage as a check that you've connected the cables with proper polarity. Not finding that, you need to press that button for the TackLife to apply voltage.
    - Having pressed Boost the green light came on at the TackLife, indicating voltage power applied.
    - Now in the driver seat I could see a flashing light indicting some life on the dashboard.
    - I tried starting the hybrid system , both with Start button alone and with Start button plus break pedal depressed. The dashboard would light up completely, but I couldn't get the hybrid system to start or the ICE to come to life.
    - The TackLife is designed so that Boost power only lasts 30 sec.s. After that time ran out, the TackLife turned off the power, and the dashboard went dead again.
    - I tried this several times without ever being able to start the car.
    So, all in all, I could not get the car to start with the Lithium jump starter. Has anyone done this successfully? Am I missing something basic?
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    When a battery is flat dead nothing but a new battery can bring it back
  3. JC91006
    16,482
    8,397
    You might have just gotten a bad battery, they normally last 5 years and are trouble free. You just have to make sure you don't let the car sit for weeks at a time.
    No need for jump starters if you replace the 12v every 5 years or so.
  4. dbstoo
    dbstoo Senior Member
    1,327
    703
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Disconnecting the battery is not simulating a dead battery. It's a fault, especially if the lithium pack disconnects itself.
    Mendel Leisk and Maarten28 like this.
  5. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    o_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_O
  6. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    so in other words you were using the lithium battery in the place of the 12v battery to see if can have hv bat to turn ice over. That’s usually when your lights beep and smell smoke like my signature.
  7. rjparker
    rjparker Tu Humilde Sirviente
    7,964
    4,709
    Texas Hill Country
    On my v I have "started" it with a small 5 amp hour alarm battery at the front jump points. No rear battery. Using electronic jumpers that were probably a thin 20 gauge. So it does not take much. But there was a battery online for the hybrid system to sense and charge. Your lithium lacked this ability. You need to use your 30 second jump pack in parallel with a real battery. After 30 seconds it is internally disconnected.
    First I recommend the Noco GB70. or one of their better models. Second, I suspect your setup was not up long enough. Anytime you totally disconnect a 12v battery the hybrid takes longer to initialize. Even then it usually takes two tries after a 12v disconnect. The Noco's also have a bypass mode but they stay on much longer. Even then, computer controlled jump packs still need a real battery in circuit.
    So your assumption that disconnecting the car's 12v would be a good test is false.
    Finally you need to find out why the battery only lasted one year. Otherwise history will repeat itself. Do a parasitic draw test which should draw 25 ma or less within a few minutes of shutdown. Again this test must be properly done to be valid.
  8. bisco
    49,446
    1) check the jump pack to make sure it has a full charge
    2) don't bother with the engine block, just find a clean bolt head etc near the jump point
    3) connect the jump pack to the battery cables in back
  9. ttou68
    ttou68 Active Member
    348
    205
    Could a Lithium jump pack simulate 310 CCA from a regular Prius battery to start it?
    I thought jump pack function as an alternator to aide a dead battery that still store plenty of charge but not enough to start a engine..
    And yes, I understand that the traction battery start the engine but doesn't it still need a healthy 12V with 310 CCA to start?
    #9 ttou68, Feb 16, 2021
  10. Mendel Leisk
    38,709
    Yeah I was wondering about this too.
    Why do all these new jump packs have super short cables. Not practical. Per other responders: you can bolt to ANY substantial bare metal, engine block OR the car body. To verify, check first for electrical continuity between engine block and prospective ground connection, with test probe or multimeter set to ohms or continuity scale.
  11. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Not necessarily true. It depends on HOW and why the battery is dead.
    It is true, however, that the very small "jump packs" are not designed to start most vehicles in the complete absence of a battery.....OR in the case that the dead battery is sapping a LOT of current from the jump pack when it is connected.
    They are not intended to work in all cases. Sometimes more power is required.
  12. sam spade 2
    7,035
    2,788
    2017 Prius c
    Because they are super thin. Not really up to the task in my opinion.
    Longer would cause more voltage drop and be more likely to overheat....the cables, that is.
    iskoos likes this.
  13. rjparker
    7,964
    4,709
    Texas Hill Country
    Because they want to package them in a small case that will go under the seat or other accessible spot when the rear hatch won't open. For a Prius fuse box hookup its not that hard if you are electricity 101 certified. I think I had this level down in third grade.
    Like many things in life, its best to try out a new tool or strategy before its a crisis in the middle of the night. On my earlier gen2 I left a note (attached) on the fuse box cover for the uninitiated. At the time I carried a set of $10 Walmart 18 awg jumper cables instead of a not yet available lithium jump pack.
    #13 rjparker, Feb 16, 2021
  14. Mendel Leisk
    38,709
    Considering the wires are thin gauge, a couple of opposing prongs ‘round back, to wrap the wires and maybe clip the clamps as well. 36” leads would be handy.
    For perspective, I have a Clore JNC 660, never seem to need it though.
  15. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    super short because super thin gauge jumper cables.
  16. ChapmanF
    15,571
    The OEM battery may say something like 310 CCA on the label, only because it wasn't practical for Toyota to find a battery of similar amp-hour capacity with CCA any lower. Measurements by others of the current during bootup have come out more like 30 amps, not 300, and generally for just a fraction of second before the car's DC/DC converter takes over.
    That said, I don't think I know enough about this situation to say why it didn't work as reported here. The details seem similar to times that I've used my own lithium jump pack (of very similar description) and it worked. If I had a very discharged aux battery and an easy way to disconnect it (which Gen 1 and Gen 2 Prii had), I would probably deliberately disconnect it before using the jump pack to start the car, and then plug it back in, just to avoid the situation where most of the jump pack's capacity gets slurped into the dead aux battery before you even get the chance to push the start button.
    This seems like a situation where if I had been there and able to poke into all the details I might have more of an idea, but it's hard to opine from a distance.
    Re: the short cables, I just put the negative clamp on one of the inverter housing bolts right near the fuse box, no problem for reach. The inverter housing is pretty much the ground of the DC/DC converter anyway, a fine choice for a grounding location.
  17. dbstoo
    1,327
    703
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    There are some jump packs that use an interesting design. They have circuitry that pulses 16 volts or more into the car's battery for 10 or 15 minutes in order to get a charge on the battery that is enough to crank the motor for a couple seconds.
  18. chronon
    chronon Active Member
    601
    105
    here and there aint be in frozen wasteland no mo..
    funny .. my 05 did jump with lithium compact jump starter .. this little brick with lights and usb and jumper cables connect capability did drag down .. but for first time use it prob. wasnt a full charge for shipping anyway .. i was able to start mine with the jump to the fr. breaker post and chasis ground ..
  19. uncertain235
    Philadephia
    Wow, thanks for the great comments folks! You're teaching me a lot.
    - Disconnecting battery is not a good simulation of a failed battery condition.
    I was wondering about that myself. Several people advice that the Prius hybrid system may need a 12 V battery present to start properly, even if mostly dead.
    - Other jump starter like NOCO GB70.
    That's interesting, I thought any jump starter should be able to handle a Prius, just because it shouldn't require much cranking current. But maybe the 30 sec. boost limit is a killer here and something like this NOCO would be better.
    - Cables short because of thin gauge, lower cost wire. Look for bolts close to fuse box. Test circuit with multi-meter first.
    These are good points. I tried would seemed like good connection points for black. Will have to look again with multi-meter in hand.
    - Best to try out a new tool before a crisis.
    Yes, my thoughts exactly. But if disconnecting the aux. 12 V battery isn't a good simulation then I'm not sure how to do it. Too bad I don't have the failed 12 V that the Toyota shop removed.
    - Need to find out why the battery only lasted 1 year.
    Yes, this makes sense. I questioned the service writer at the Toyota shop carefully on what the root cause might be. He had already lost my confidence when he didn't think to check the service record of my vehicle for history, given that it has never been serviced anywhere but in that one shop. But he told me that the technician had run the full suite of diagnostics and turned up no problem except the battery itself. Maybe I'm going to have to learn about this "parasitic draw test".
    I wrote to the manufacturer of the jump starter, wondering if they might have tips for use with a Prius, like maybe a trick to make the boost interval last longer. They haven't responded yet, but probably won't at all. Chances are high this jump starter is going to get shipped back to Amazon.
  20. uncertain235
    Philadephia
    In case anyone is interested, here’s a follow up.
    I decided I would try once more to jump start my 2011 Prius using the TackLife T8 I had bought from Amazon. I expected it wouldn’t work any better than the first time and I’d soon be packing up the device for return.
    Before starting, I followed one point made in this thread which was to probe around with a multi-meter for a good place to attach the negative clamp. It took a while, but eventually I did find a good place within reach of the short cable.
    Then I went back to the same method as before, which was to simulate a dead aux. battery by disconnecting the positive cable in back. Several people in this thread pointed out that this might not be a good simulation. But I don’t have any other method available so I did the same thing the 2nd time around.
    Having simulated the dead battery I pushed the Boost button on the TackLife, went to the driver’s seat, pressed the break and pressed the start button. Tried that twice without success. But on the 3rd try it worked! The “Ready” status showed up on the dash and, after 20 or 30 seconds, the ICE started. I repeated the procedure 2 more times and this time it worked each time on the first try.
    I don’t really understand what was different the 2nd go around from the first. Could it really just be the way the jump starter neg. clamp was connected? The first time, it went through a long jumper cable to the engine block. This time it was connected with just the short cable, to a place close the positive jump lug in the fuse box. Hard to believe that would make a difference but I don’t have any other explanation.
    So at this point, I’ve decided to keep the unit. I’m thinking that in a real emergency I should be able to finagle it well enough to get it to work.
    By the way, the vendor did eventually respond to my e-mail support inquiry. They sent the manual which I already had, they repeated obvious points like making sure the unit was charged. I wrote back to them, before I had gotten the unit to work, saying that I thought the real problem was that the Boost interval only lasted for 30 sec.s and probably it needed 60 or 90 sec.s. I pointed out that a hybrid should not draw much current from a jump starter since the 12 V battery doesn’t do the real cranking. So the device could probably handle 60 or 90 sec.s of Boost on a Prius with no problem.
    Of course they didn’t get it. The person at the other end probably wasn’t at all technical and was just working from a script. But what did surprise me was that they assumed the problem was not enough CCA so they offered to send me the next larger model, TackLife Pro, at no charge, and without requiring me to send back the unit I had. At this point I don’t need it but I was interested that the company was trying to be responsive.
    One other thing is that this experience got me wondering how much current a Prius does require form the 12 V aux. battery to get the hybrid system started. I googled a bit and found this great article: irobin_org_prius_startup_startup.
    The conclusion there is that it’s usually around 30 A peak but sometimes as high as 60 A. His overall conclusion was that around around 90 Amp-Seconds of juice is required.
    Anyway, thanks again for the help provided in this thread!
    rpp likes this.
