can't log in on one of the PC
Discussion in 'PriusChat Website Questions' started by Former Member 68813, Mar 24, 2015.
  1. Former Member 68813
    3,524
    981
    US
    using firefox, the popup with the sign in dialog never shows up. IE works, but it's buggy, looking awful, and with a lot of navigation not working correctly.
    on another PC with similar configuration, no problems.
    not sure the problems. both PC have the same version of windows and firefox with similar settings (Adblock+, private browsing, etc).
  2. sfprankster
    sfprankster Active Member
    443
    490
    Santa Cruz Mountains, CA
    Are you using any plugins that block information being sent to the website to remain anonymous?
    Ghostery?
    Disconnect?
    ...or others?
    You will need to disable them to login initially, then you can re-enable afterwards.
    I know Ghostery blocks the login screen from appearing.
  3. fuzzy1
    10,175
    No problem with Win7 / Firefox on my end. But I can't speak to the login window popup, mine is set to auto-login.
  4. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    There's an updated version of the theme that PriusChat runs that may fix that issue.
    Or it could be the AdBlocker. As someone who makes their living off of ad revenues, I'd appreciate you whitelisting priuschat.com from your AdBlocker, anyway.
