Can't open fob to change battery
Discussion in 'Gen 2 Prius Main Forum' started by eadoherty, Mar 6, 2019.
  1. eadoherty
    eadoherty New Member
    Washington, DC
    We've changed the key fob battery before but now that the battery is dead again, I can't open the fob. Tried loosening with a thin blade, took it to a watch repair place but no luck. Can't get the plate off to change the battery. Any suggestions? Thanks!
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
  3. eadoherty
    Washington, DC
    Yup, won't slide off as shown in the instructions you posted.
  4. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Seems like having a functional fob is fairly important, best to keep working on it until it opens up.
    Since you mentioned attempting to using a thin blade, I will assume that you've already watched the youtube video.
    If you get stuck (or break the case), below is an instructable on case replacement. Cases can be bought online for $8-10 (give or take).
    DIY Toyota Prius Key Fob: 3 Steps
    Don't throw away the old case until you're quite sure the new fob works as intended :whistle:
    edit: forgot to include the link, doh.
    #4 SFO, Mar 6, 2019
    Skibob likes this.
  5. bisco
    49,577
    ask a dealer how much for a battery replacement
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,268
    5,965
    Columbia, SC
    To remove the key portion, the small lever must be pulled to the side. This small lever must also be pulled to the side in order to slide the back off. Just wanted to ensure that was clear, as some instructions aren't very specific about it.
    From another thread:
    Make sure the manual key is removed.
    Hold your right hand in front of you with palm up.
    Place the FOB near the middle of your 4 fingers with the buttons down and the raised lip (on the back of the FOB) away from you.
    Place your right thumb on the fob Toyota symbol (the center of the back)
    Use your left thumbnail to move and hold the slide release button completely to the right
    Using your right thumb, push firmly toward the raised lip (away from you).
    The back of the FOB should slide off.
    Skibob and srellim234 like this.
