Can't play MP3 files
Discussion in 'Gen 2 Prius Audio and Electronics' started by maharlika, Oct 11, 2008.
  1. maharlika
    maharlika New Member
    SC
    I just got a 2009 Prius, standard base package. I can't play my homemade MP3 music cd's in it. Only CDa formats play. These MP3's play fine in my other car. How do I make it play MP3's?
  2. wayside
    wayside New Member
    30
    I had the same problem. I was just making data discs and the prius stereo would not recognize them. My laptop is Vista which I didn't think would be a problem but when I burned a data disc on an XP machine it played perfect.
    Not sure if there is just a problem with my laptop (yeah I know, besides that it is Vista) or what but I have enough XP machines around that it isn't really worth investigating.
  3. maharlika
    SC
    I've used XP and Vista, with various different CD burning software, with the same result: no MP3's will play.
  4. wayside
    wayside New Member
    30
    Use XP and just create the data disc with windows explorer (no need for any extra software).
    Make sure you close the session and you should be good.
  5. bredekamp
    bredekamp Member
    569
    Somerset West, South Africa
    Make sure they are actually mp3 files and not AAC, AIFF, Apple lossless etc. Only MP3 files or WMA will work.
    Oh yeah (thanks qbee42) check that there is an MP3/WMA logo on the front of the RADIO/CD unit....
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Does the base model play MP3s? I know it didn't on the earlier Prius. You had to get the JBL system for any of the fancy features (if you want to call that a fancy feature.)
    Tom
  7. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    you need a prius with options, package 2 at least to be able to play mp3 files...
    you can also diagnose problems with mp3 files by checking out my post in the knowledge base that was posted recently 'prius lan check codes and their meanings'. the mfd logs problems with mp3 files, such as cd rom abnormal, mp3 files that were not mp3 fles, mp3 decode errors, etc
  8. rigormortis
    1,340
    26
    san jose, ca
    i guess we can add mp3 playback along with Vehicle Stabilty Control to those useless
    is the back up camera worth it threads.
  9. bredekamp
    bredekamp Member
    569
    No, I love the mp3 playback capability. Changing CDs is a pain. This way I can fit several hours of music into the 6 disc shuttle. VSC hauled my a$$ out the fire at least once. Backup camera is nice, but that's about it. I don't have one. To make sure there are no cats around when I reverse, I honk the horn briefly and wait for the engine to come on before I move the car.
