Can't remove blade key from 2015 Prius C 2
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by willym, Dec 25, 2017.
  1. willym
    willym Junior Member
    Boston
    2015 Prius c
    Came back from driving around all day, parked the car, put it in park, but the blade key won't come out, and I can't turn the car all the way off. Any suggestions?
    I'm concerned that if I leave the key in, with the car not totally off, the 12v battery will drain quickly.
    Any suggestions?
  2. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Have you tried turning the steering wheels some degrees, and see if the key comes out?
  3. willym
    Boston
    2015 Prius c
    Yes, and the steering wheel doesn't lock like it normally does. Seems connected?
  4. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    is the gear locked in place? try rocking the car back and forth, jimmy the gear handle and try again.
