Can't Seem To Get Heater Working Again
Discussion in 'Prius c Main Forum' started by Lukey51, Jan 12, 2020.
  1. Lukey51
    Lukey51 Active Member
    203
    108
    TN
    It worked fine the other day when I pushed the "Auto" button. Then the Auto and AC buttons were lit up, the the screen showed the temp which I set at about 68 and it worked good. Today when I pushed the Auto button, it lit up while I held my finger on it but as soon as I took my finger off it, it went off. The front and rear defrosters seem to work but not the auto button to use the climate control. TIA for any advice on this.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Check ALL of the climate control buttons to be sure that none of them is stuck down.
    My first C had that problem......but don't remember which button it was.
  3. Lukey51
    203
    108
    TN
    That was it. The "stop" button was somehow pushed in. Thank you.
  4. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Yep the sticking "OFF" button is quite the common problem in the "c"
    I am so used to it, I always tap it a few times before turning on the climate control
    Lukey51 likes this.
