Cant shift to drive
Discussion in 'Gen 2 Prius Main Forum' started by Jadkins, Jun 16, 2016.
  1. Jadkins
    Jadkins New Member
    Greensboro
    So my wife says she hit a curb last nite on her way to work, now this morning the car lost power several dash lights are on and the lcd display says problem on start up, and has a orange icon at the top left. It will only shift between park and neutral. The light on the power button wont turn green either. Currently I'm waiting on a tow truck. Any thoughts or suggestions on what could of happened would be greatly appreciated.
    Update: Problem solved! It was the 12 volt battery and it was on its last year of the warranty so that was a qiuck no cost fix. Thanks everyone.
    #1 Jadkins, Jun 16, 2016
  2. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    What area of the car was damaged?
  3. Jadkins
    Jadkins New Member
    Greensboro
    From what I can tell the right side of the front bumper is the only thing messed up
    51,140
    welcome! maybe trans axle damage. how old is the 12 volt battery?
  5. Jadkins
    Jadkins New Member
    Greensboro
    I replaced the 12 volt about 4 or 5 years ago. The damage appears to be just cosmetic I took a look at the front end while he was lifting the car tho I haven't had a chance to thoroughly check it out yet. Could it be the battery?
  6. bisco
    51,140
    it's worth testing. if the wheel hit the curb, you probably won't see the damage.
  7. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    The right side as in the passenger side?
