Can't sync address book from phone. Manually add names?
Discussion in 'Gen 2 Prius Main Forum' started by OlsonBW, Jul 15, 2007.
  1. OlsonBW
    OlsonBW New Member
    254
    Ok, I've got a cell phone (RAZR) with Verizon wireless. It will not sync my names and numbers even one at a time. I've tried everything that people have posted on here (I did a search).
    So, can I manually, with the phone 2 feet or 17,000 miles away and with it powered off and kept off, can you manually add names and phone numbers to the Prius? Can you then "call by name" with them?
    Thanks in advance. And yes I looked in the manual. And no I can't find it in there about this specific thing.
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    I feel your pain. I have an AT&T Sync (Samsung SGH-A707) that won't. The phone disconnects after it connects to the Prius when trying to transfer. I got fed up and keyed in the important numbers, like home, on the MFD. Worked fine, I could then add car phonebook numbers to the speed dial screens and even add voice dialing. The car and the phone work OK together to make calls, other than the car not showing the signal strength or phone battery level. I traded a Sony Ericsson S710a, which stopped sending text, for the Sync. That phone was more compatible.
  3. OlsonBW
    OlsonBW New Member
    254
    <div class='quotetop'>QUOTE(Bill Merchant @ Jul 15 2007, 10:57 PM) [snapback]479491[/snapback]</div>
    I guess I'm just being stupid then. I've got an '07 without NAV (but pretty much everything else including bluetooth) but can't figure out how to add them manually. I looked in the manual and I'm not seeing the instructions. I'm usually good at figuring things out. I fix computers for a living but isn't seeming to help.
  4. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(OlsonBW @ Jul 16 2007, 10:00 AM) [snapback]479556[/snapback]</div>
    From my memory alone, if you press the steering wheel off hook button while NOT moving, it should go to 'home screen' of the phone interface (as opposed to the Quick Dial screen when moving). At the bottom there is a Settings button, and within there should be a Phone Book button. Just press Register and start programming away.
    As far as BT phonebook transfers, I have the Motorola KRZR phone (k1m, I believe), and while I am able to transfer ONE number at a time, it is so tedious that it is pointless. For each transfer, I need to go into the phonebook setup as above and set the car to receive transfer - which disconnects the 'headset' phone connection - then go into my address book on the phone and transfer. It then sends the data in a couple seconds, then disconnects the data session from the phone (!) and goes back to the regular 'headset' connection. I then have to manually go back into phone book setup, transfer, etc... and re-initiate the whole process again to transfer another phone number. It is just an absurd process for a one-by-one transfer... it is much faster to simply program the car phonebook manually. <_<
    Perhaps it would be worthwhile if you can transfer a large portion of your phonebook in one shot, but by the sound of it, phones/providers that allow this are few and far between.
  5. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Sarge @ Jul 16 2007, 08:45 AM) [snapback]479601[/snapback]</div>
    I got a non-Verizon phone (Sony Ericsson) off of eBay, put the phonebook in that and sent the phonebook in one shot. I needed a sim card, but didn't need service.
  6. hill
    8,925
    I feel your pain, my fellow Verizon skumbag users of Vcast crap Payola worthless software designed to take your money for stupid wallpapers & tunes, while most all other cel providers throw it in the feature (that comes stock on the phone but Verizon disables it) for free. Don't even ask me how I REALLY feel :p
    You CAN do it, but it's a pain in the arse work around. The search tool can be your friend, so get busy! :p
    Sorry, I looked ... used it ... but can't find it now.
  7. OlsonBW
    OlsonBW New Member
    254
    Thanks Sarge. I'm printing this off and taking it with me to try it out tomorrow.
    <div class='quotetop'>QUOTE(aaf709 @ Jul 16 2007, 09:40 AM) [snapback]479642[/snapback]</div>
    Great idea. I'll check with my friends and see if they have an old Sony Ericsson sitting around unused.
    <div class='quotetop'>QUOTE(hill @ Jul 16 2007, 11:22 AM) [snapback]479708[/snapback]</div>
    Hi (King of the?) Hill - I did the search and followed the instructions I found but didn't find the menus they were talking about. I'll try Sarge's instructions and see if those work.
    I've talked to maybe a dozen Verizon people on the phone and in person about this syncing issue and they keep trying to tell me that most of their customers are business customers who don't want their address books and calendars ripped off. They "say" that's why they do it.
    It (supposedly) used to be a choice that people could activate it (so THEY say) but they turned it off because people would activate it, get their stuff stolen and then complain. I asked them how they -knew- it was stolen and the Verizon people started making up crazy scenarios and then started saying it was Paris Hilton getting her phone numbers tapped.
    I told them if I had 500 people hounding and trying to hack into my phone all day they could probably break in too. But nobody cares about my phone numbers. You want to call my family friends? Look them up in the phone book.
    Fine, I told them. The next phone I get with be an Apple iPhone from Cingular (now AT&T). Even if their service sucks, at least I'll be able to use all the features of the phone.
    They didn't like that answer.
  8. KTPhil
    KTPhil Active Member
    1,379
    22
    "From my memory alone, if you press the steering wheel off hook button while NOT moving, it should go to 'home screen' of the phone interface (as opposed to the Quick Dial screen when moving). At the bottom there is a Settings button, and within there should be a Phone Book button. Just press Register and start programming away."
    Bold part doesn't work this way on my '05. When I hit Phone Book it tells me that it is empty (and therefore uneditable).
    Yeah, I have Verizon...
  9. Sarge
    Sarge Senior Member
    1,325
    785
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(OlsonBW @ Jul 17 2007, 03:13 AM) [snapback]480111[/snapback]</div>
    You're welcome... hopefully my instructions were right, it was from memory. ;) Basically, just press the phone button when you are not moving and go into Settings and it is pretty self-explanatory from there.
    IMHO this is bogus. There is NO chance of someone tapping your information, since it is not a 'dynamic' link. You need to set the car to receive, then initiate the transfer from your phone. Adding a contact to your phone will not make it "magically" appear in the car's phonebook without a manual transfer.
    Sounds like someone was talking to make themself sound smart. As for the real reason, I don't know for sure, but I am sure it is not a worry that someone can "steal" your information. ;)
    Heh heh... always a good strategy to threaten to leave. Usually works, provided they have the power to change what you don't like, though I suspect in this case they can't do anything as the limitation likely comes from above...
  10. OlsonBW
    OlsonBW New Member
    254
    I won't have a chance to test it until about 5:30 PST.
  11. OlsonBW
    OlsonBW New Member
    254
    Thank you very much. That worked.
    I didn't get all of the ones in that I wanted but I did get about half a dozen. Now to see if I can voice dial by name or if I have to do something more. I'll do that tomorrow since I'm driving into work alone (normally my wife and I car pool together) so she can't bug me as I test it out.
    With us getting 50.6 mpg right now (we had a high of 51.4 two weeks ago - too many hills since then), does that mean we average 101.2 mpg since there are two of us?
    PS: I can fix 70 computer issues in one day and can't figure out how to program the Prius' phone's address book. (shaking head in shame).
  12. ZA_Andy
    ZA_Andy Member
    219
    VA
    <div class='quotetop'>QUOTE(OlsonBW @ Jul 18 2007, 12:29 AM) [snapback]480711[/snapback]</div>
    You'll have to add voice tags to each entry you want to be able to dial by name. I can't remember exactly how that's done, but it's another step from within each entry in the phonebook.
    It's one of those things that the manual explains badly and which the terminology used by Toyota makes more obscure than it should be. It makes programming the thing about as intuitive as knitting a pair of socks behind your back with a blindfold on and wearing thick rubber gloves!
  13. OlsonBW
    OlsonBW New Member
    254
    <div class='quotetop'>QUOTE(ZA_Andy @ Jul 18 2007, 04:49 AM) [snapback]480806[/snapback]</div>
    I agree with that. Geez, I spent about 20 minutes in the car before I figured out the first one. Then after that I got it but man, like eight pushes to go from one to the next. What were they thinking? I got about 10 of the 20 voice tags done before our cat and then our wife comes out in the garage and starts both start gabbering at me asking what I'm doing and when I'm coming in. (I feed the cat and as a cat slave I wasn't taking care of him first.)
  14. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    <div class='quotetop'>QUOTE(OlsonBW @ Jul 17 2007, 09:29 PM) [snapback]480711[/snapback]</div>
    Actually, the term is seat miles per gallon. You multiply MPG by the number of passengers.
    Aircraft often use SMPG in their fuel-economy stats.
