Can't tell if my dipstick is showing low oil...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by HDuncan, Apr 25, 2015.
  1. HDuncan
    HDuncan Member
    122
    30
    I see oil on the sides but not on the center... Does this mean I'm low???
  2. JC91006
    16,482
    8,400
    I don't see oil. Best to change it if you haven't. 3.8 quarts should do it
    HDuncan likes this.
  3. Mendel Leisk
    38,735
    Try putting the dipstick in just to the shoulder of the handle, see if you can see a shift of any distinctive edge.
    Also, be sure to flip it over, one side's sometimes easier to read than the other.
    Third gen dipstick is similar: a lot of smearing up the edges, hard to read. My best guess (and that's an excellent picture): your oil level is right at the bottom dimple. Maybe... :ROFLMAO:
    HDuncan likes this.
    49,506
    i think menders right. the consensus is the edges don't count, it's where the full coverage ends. i don't think anyone knows for sure. if you change it as jc suggests, you'll get a benchmark.
    HDuncan likes this.
  5. Mendel Leisk
    38,735
    Try putting in about a cup. If it IS at that bottom dimple, you should be able to see it go up.
    HDuncan likes this.
  6. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    How long was the car off before checking? The longer the car is off (longer is better: hours, overnight), the easier it will be to read. I've noticed what you notice when checking after just getting gas: no readable reading.
    And you'really checking while on a level surface too?
    cyberpriusII and HDuncan like this.
  7. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    I agree that the oil level isn't even to the first dimple.
    douglasjre and HDuncan like this.
  8. HDuncan
    HDuncan Member
    122
    30
    I drove the car around and measured again on the street (more level than my driveway).
    If I plunge the stick in and out really fast, I can get a sharper reading. I added some oil and got the line to about halfway up....
    I think I'm good, guys! Seems I was definitely low!
  9. JC91006
    16,482
    8,400
    The oil level between the 2 marks is 1.6 quarts. Half way it would require another. 8 quarts or so. But seeing the history of this car or lack of history, I would just change the oil and start monitoring how much it burns. Add as needed over the oil change interval
    HDuncan likes this.
  10. exstudent
    2,213
    901
    Torrance, CA
    Looks like It was low then. Do get into habit of checking regularly: after ever gas fill-up (w/ enough time for oil to get back into oil pan), ever week, every other week, once a month. Just do it regularly.
    HDuncan likes this.
  11. HDuncan
    HDuncan Member
    122
    30
    Once the car gets to 150k, is it common for them to consume oil more regularly?
    I'll definitely get the oil changed soon. It's about 4k since the last one. Regular oil. I just wanted to make sure it had enough until I get into the shop
  12. JC91006
    16,482
    8,400
    Since the car is new to you, you need to monitor how much it burns. All 4 of mine burn oil. Lowest mileage is 75k to 166k. So there's no telling when it starts.
    From your information, it has burned at least 1.6 quarts in 4000 miles. This is assuming it was completely full after the oil change
    #12 JC91006, Apr 25, 2015
    HDuncan likes this.
  13. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,136
    1,582
    Iowa
    Seriously guys....OP never said how long the car sat before checking oil -- except for the one where the check was done immediately after the "drive around."
    Exstudent was dead-on. NEED to leave the car alone for at least three hours on a somewhat level surface to get an accurate reading.
    I, personally, would be very uncomfortable adding oil after a quick pull right after I drove.
    And, even after sitting for several hours, sometimes, I can't tell at all on one side of the stick, but if I turn it over, the level is very obvious.
    My car never uses oil and I change it myself and I put in 3.5 quarts at each oil change. Right after the oil change it is a bit hard to see, but after driving for a couple of days, no issue -- as long as I let it sit for several hours before checking.
    Listen to Exstudent -- there is a chance -- however slight -- but a chance -- that it is now OVERFILLED.
    HDuncan likes this.
  14. JC91006
    16,482
    8,400
    Don't scare the guy, no chance it can be overfilled. He's .8 quarts low.
    Mechanics don't wait 3 hours to check your oil level after a change, slow draining to the pan will make up a very slight amount on what you see on the dipstick.
    HDuncan likes this.
  15. Stevewoods
    Stevewoods Senior Member
    648
    993
    Seattle, WA
    I don't think anyone is trying to scare anyone....but neither should one give false hope. I agree we don't know enough to know that the oil was under the bottom mark. And, of course mechanics don't wait hours to check the level after an oil change....and mechanics also DON'T have customers come back so to adjust tension of various belts, etc. after replacement after a few days of driving either, although all the manuals tell you to do just that.
    It is even recommended to check the torque of your lugnuts after install a couple of days after driving, but never had a tire shop tell me to come in and have that done (although, If I did, I am sure they would).
    Exstudent was right. Period.
    #15 Stevewoods, Apr 25, 2015
  16. JC91006
    16,482
    8,400
    Nobody is giving false hope. Op took picture again after adding oil and it's halfway on the 2 dipstick marks. That's sufficient oil to run the car safely but is .8 quarts low from the full mark.
  17. Stevewoods
    648
    993
    Seattle, WA
    Sounding like a broken record....:)
    But, as Exstudent said....when was the picture taken. If right after driving, it is NOT an accurate representation of oil levels.
    Off to Pike's Place market to buy salmon -- I know the oil level in the salmon....:LOL:
    HDuncan likes this.
  18. HDuncan
    HDuncan Member
    122
    30
    Just to clarify, the first image I posted was when I checked the car cold after it had been sitting all night. I couldnt get a good look at it, and I could get a perfectly fine read on my 06, thats when I started worrying that it might be too low to show up. The subsequent checks were done while the car was warmed up.
    Just to be safe, I will let the car sit on the street for 4 hours and check it later this evening and I'll post a photo to ensure it is still within the acceptable range (y)
    If I somehow overfilled it, I'll just do an oil change, which I plan to do anyway. I just happened to have some leftover oil from the last oil change (I usually give the shop 3qts and tell them I will fill up the remainder myself =)
  19. Stevewoods
    648
    993
    Seattle, WA
    O.K.
    That is what we needed to know. The car sat all night. But without knowing that Exstudent was right.
    And, also, as mentioned, sometimes, I have to turn over the dip stick, tilt it this way and that and otherwise chant to the gods to get a good visual on my Prius oil level also.
    No idea why....
  20. Mendel Leisk
    38,735
    I don't the oil has to sit that long for accurate reading. It might get slightly higher, not much though. If I shut down, pop the hood, check the oil, then wait an hour, or two, and check again, not much difference.
