Can't turn off A/C
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by gsmckee, Jun 16, 2016.
  1. gsmckee
    gsmckee Junior Member
    Sacramento
    I just noticed this morning that I can't turn off my air conditioner. When I hit the off button nothing happens. This use to work but now it doesn't. I can still change the temp and the air conditioner still works just fine. The green indicator lights are still lit. Any suggestions?
    iPhone ?
    LnG likes this.
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    My uneducated guess would be that you have a faulty switch.
    51,625
    are you talking about the off button for the fan?
    is it a button, or touchscreen?
    anything on the steering wheel?
  4. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    My AC Off button gets stuck occasionally. Moving it around seems to let it depress and fixes the issue.
    STLmayor and gsmckee like this.
  5. Mendel Leisk
    41,064
    Toyota Owner's Manuals (at least ours, for 2010 Prius) muddy the waters by referring to the entire ventilation system as "Air Conditioning", whereas at least in North America AC means the active cooling of air, via compression/decompression of some Freon-like gas. Maybe OP can clarify?
  6. gsmckee
    Sacramento
    Just to follow up - it was a stuck button and once I shifted it things now work again.
    iPhone ?
    Mendel Leisk and bisco like this.
  7. bisco
    51,625
    i am finding my buttons a bit sticky lately. disappointing after only 4 years and 40k.
  8. Zipy
    Zipy Junior Member
    25
    Independence, MO
    2012 C, same problem here. Sticky buttons. About the same mileage- 40k. Anyone check for a service bulletin yet?
  9. LnG
    LnG Junior Member
    73
    23
    Northern Hemisphere
    2016 Prius c
    My lights don't stick on, but the air still comes out with it off. It will heat or cool depending on what the temp was set at last. I can't turn it off but I can set the fan speed low.
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    THAT is not a problem. It's the way the system is designed.
    Some air moves all the time to help prevent fumes from building up in the cabin.......mostly incase of an exhaust leak.
    It should automatically set the fan to LOW when the system is "off".
  11. LnG
    LnG Junior Member
    73
    23
    Northern Hemisphere
    2016 Prius c
    Ok. I didn't really notice it until I went through the car wash and big rush of air came in. Thanks
