Car Antenna in Car Wash
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mparrish, Jan 28, 2007.
  1. mparrish
    mparrish New Member
    45
    Austin
    Has anyone ever taken their Prius through an automated car wash? And if so, have you had any problems with the antenna on the roof? I found myself wanting to go through one today, but didn't because of the visions of those huge rollers snapping the doggone thing.
  2. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(mparrish @ Jan 28 2007, 04:50 PM) [snapback]382033[/snapback]</div>
    Then do what it says in the manual and remove it before sending it through. I do know someone who ignores this and has been lucky so far.
    - Tom
  3. MegansPrius
    MegansPrius GoogleMeister, AKA bongokitty
    2,437
    27
    Chicago, IL
    <div class='quotetop'>QUOTE(Tom_06 @ Jan 28 2007, 06:51 PM) [snapback]382049[/snapback]</div>
    The antenna unscrews very easily by hand.
  4. Tideland Prius
    16,445
    If you're going through the brushes, take it off!
    I've had no problems with touchless ones. The overhead bar clears the antenna. Again, do so at your own risk.
  5. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    <_< One of the first modifications I made was to replace the original whip antenna with a stubby antenna [found on eBay] - in my case I chose a 2". Receiption seems the same around the Dallas metroplex. When I drive "cross-country," I replace the original whip.
  6. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    I didn't take it off the few times I have been to the car wash. Will take it off when I wash it again. B)
  7. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    I just remove mine takes less than 60 seconds..... :rolleyes:
  8. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    Depending on how much the radio is used and if a Prius owner intends to frequent car washes, one might consider replacing the factory antenna with one of the popular, aftermarket 'shark fin' radio antennas.
    While stylish and significantly reducing the possiblity of a car wash brush removing it, the trade-off of the 'shark fin' radio antennas is reduced radio reception.
    Using a 'shark fin' would actually make even more sense if someone were also using a satellite radio service in their Prius.
  9. fphinney
    fphinney Member
    234
    Walnut Creek CA
    I too, know about the advisability of unscrewing the antenna before venturing into a car wash.
    However - - I keep forgetting. I have actually removed it once. And my antenna has survived the big rotating brush car wash twice with no apparent harm -
  10. lembers
    lembers New Member
    Just unscrew it. It's only hand tight.
  11. robincx
    robincx "Fear is the mind killer"
    1,294
    North Boston, NY
    <div class='quotetop'>QUOTE(mparrish @ Jan 28 2007, 05:50 PM) [snapback]382033[/snapback]</div>
    Ran mine through the rolling monster today with no apparent damage.
  12. Tom6850
    Tom6850 Retired
    898
    Leesburg, FL
    The car wash I use takes the antenna off and gives it to me then tapes the rear wiper blade down before I go through, when I get to the towel area they reinstall the antenna and remove the tape from the rear wiper blade. They do the same with any car with removable antennas and rear wipers.
  13. itsme
    itsme New Member
    68
    we have found a laser automatic car wash that does an fantastic job and if you go through slow at the begining you get a geat under carrage wash also. nothing touches the car but soap water and spot free rinse water no rollers no dryers come down very nice .
    so 21st century for a small town..lol
  14. Highly ImPriused
    Highly ImPriused Impressive Member
    250
    Western NY
    I never go to the brush/roller type car wash anymore. If you think about it, a lot of grit and grime from other cars could be stuck on there and end up scratching your finish. I always go to a touch-free laser wash. As an added benefit, you don't have to worry about the antenna.
  15. LABBOO
    LABBOO New Member
    Luckily I went to the laser wash for my first one last week, because when I tried to take off the antenna I couldn't reach it!
  16. ServoScanMan
    ServoScanMan Member
    262
    Lorena, TX
    <div class='quotetop'>QUOTE(Highly ImPriused @ Mar 26 2007, 12:05 PM) [snapback]412362[/snapback]</div>
    Same here. After you take a car thru a brush type washes a couple of dozen of times, you will notice scratches in the paint surface. I always wash mine by hand. This also helps me to stay one with my Prius. ...ummmmmm :)
  17. adam1991
    adam1991 New Member
    218
    My Prius is a car. It needs to stay clean as a matter of simple maintenance, but it doesn't need hand washing. The dealer has a free anytime you want it car wash that I use on a regular basis.
    I don't need to stay one with my Prius any more than I need to stay one with my Bic pen.
    Here's an idea: next time you browse through this forum, as you read, replace the word "Prius" with the word "Taurus". See how silly many posts sound.
  18. onlynark
    onlynark Member
    189
    bay area
    <div class='quotetop'>QUOTE(adam1991 @ Mar 31 2007, 11:32 AM) [snapback]415477[/snapback]</div>
    yes, I am sure if you replaced the word "Prius" with the word "Taurus" in the following post, "My Prius got 68 MPG!!!" to be "My Taurus got 68 MPG!!!" I am sure it would sound silly.
  19. adam1991
    adam1991 New Member
    218
    yeah, just like a thread titled, "Do you always park next to another Taurus?" sounds ridiculous.
    As ridiculous as, "Do you always park next to another Prius?"
