Car cannot start - inverter cable?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Marvel800, Nov 14, 2024.
  1. Marvel800
    Marvel800 New Member
    ann arbor
    fellow Prius owners,
    I have a 2014 Prius V 5. I changed the inverter pump and in order to do so, I removed the inverter. There were no major problems while trying to remove it (as far as I can tell, nothing broken, no major struggle with anything, etc.) After replacing the pump, I noticed the cable does not "lock" anymore - it comes off rather easily with a slight tug. Furthermore, the car can no longer start. I'm not sure if the two are related or not. Does everyone has any idea? I've enclosed a few pictures of the connector (both male and female ends).
    I thought it might be the battery, but I've charged it up to 100%. I also made sure the HV lock is firmly and correctly in place. I also verified all the battery connections are secured.
    Thanks!
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,485
    5,808
    Texas Hill Country
    If you can’t lock the connector it is not going in correctly.
    I would look at the orange seal which may be displaced.
    Brian1954 and Air_Boss like this.
  3. Marvel800
    ann arbor
    I looked at it again and the orange seal looks where it is supposed to be. I've enclosed a few pictures of different angles. Can you see anything? It just doesn't lock into place and the car cannot start. Are they related?
  4. Air_Boss
    Air_Boss Senior Member
    4,132
    1,151
    New Yawk
    From appearances, the orange seal should be down-hole, serving as an edge seal on the mating connector.
  5. rjparker
    9,485
    5,808
    Texas Hill Country
  6. Marvel800
    ann arbor
    The orange seal is all the way down (you can see it from the pictures). I don't know if it can be pushed down any further.
  7. Air_Boss
    4,132
    1,151
    New Yawk
    Can the orange seal be pushed in tighter to the connector so it edge seals/laterally, but doesn’t impede vertically/axially seating the connector?
  8. Marvel800
    ann arbor
    Can you explain what do you mean by "down-hole"?
  9. Marvel800
    ann arbor
    The orange seal is like a rubber band right? It already wraps around the connector. I made sure it was more or less aligned around the entire connector in equal distance. I am not sure why Toyota made it so hard to reattach this connector.
  10. rjparker
    9,485
    5,808
    Texas Hill Country
    It’s not hard if everything is right
  11. Marvel800
    ann arbor
    I have quite a bit of experience and knowledge on automobiles, and I tried everything I can think of. I just can't figure out why it is apparently unable to go in all the way. The orange seal seems to be in its proper place because there are grooves where it is apparently meant to keep it from moving. I don't know what else to try; I guess I need to take it into the dealership.
  12. rjparker
    9,485
    5,808
    Texas Hill Country
    Perhaps the seal is swollen up due to cleaners or solvents. Otherwise I would suspect a bent pin or socket assuming no foreign objects.
  13. Air_Boss
    4,132
    1,151
    New Yawk
    Those are designed as tight clearance seals and connectors. I still suspect that orange gasket placement is the issue. It may as suggested, be torn, swollen or partially displaced/dislodged from its design location..
  14. Marvel800
    ann arbor
    I've attached a picture of the connector. There does not seem to be any bent pins.
  15. Marvel800
    ann arbor
    Can these seals be replaced separately?
  16. Brian1954
    Brian1954 Senior Member
    1,699
    663
    South Central PA, USA
    Remove the small orange seal and see if the connector will install correctly. If it does, then you know where the problem is.
    Air_Boss likes this.
  17. rjparker
    9,485
    5,808
    Texas Hill Country
    The cable has pins as well
  18. Air_Boss
    4,132
    1,151
    New Yawk
    If the orange seal ends up between the face of the plug and bottom of the jack, it probably interferes enough to keep the connector from locking. Still think the orange seal should be nearly flush and barely visible, serving as an edge seal as the plug passes it.
  19. Marvel800
    ann arbor
    I removed both orange seals and I still cannot get into lock. In other words, if I apply some force (not a whole lot), the connector will come right off. Does this connector need to be secured before the car can get into ready mode?
  20. ChapmanF
    17,178
    More'n likely.
